LarryWilliams Posted September 23, 2013 Share Posted September 23, 2013 Just got this a few weeks ago. I have created some patches I like but the one thing I cannot figure out is HOW to get the TAP tempo to work with the delay. I am creating sounds in the latest Workbench. The only way I can change sounds is there. I can turn the delay on or off at the POD footswitch, but using the TAP switch does nothing except change the speed of the flashing light around the switch. Can someone help? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 23, 2013 Share Posted September 23, 2013 (I presume you mean HD500 Edit, not Workbench.) You need to set the Delay FX parameter to one of the note-based settings, not a specific bpm. If you set the Delay to a specific bpm, that overrides the Tap Tempo feature. If you set the Delay to something like a 1/4 note, or an 1/8 note, then the Tap Tempo feature will work. Quote Link to comment Share on other sites More sharing options...
LarryWilliams Posted September 23, 2013 Author Share Posted September 23, 2013 I am pretty sure I did that. But I will try that again tonight. The tap feature works perfectly with the factory presets. So, I know it functions. Yeah, HD500 Edit. Quote Link to comment Share on other sites More sharing options...
