Pod Hd500 Cd/mp3 In Does Not Output Stereo
pod hd500 cd/mp3 in
5 replies to this topic
#1 erickim
erickim
  • 2 posts
  • Registered Products:3
Posted 24 September 2013 - 06:12 AM
Recently, maybe I've never noticed before, I noticed my MP3 input jack only provides right signal through my headphone on HD500. I checked my cable, iPod, and headphone and they work fine as they should. But when iPod is plugged into CD/MP3 jack, I only hear my jam track through my right ear. While I hear my guitar both right and left, I hear my jam track on my right ear only. Left signal is really really faint. Is this how it supposed to be or can I change my configuration on HD500?
Thanks for your help.
Eric
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 24 September 2013 - 06:50 AM
That's very odd. I would recheck your equipment. Make sure the plug you are using from you iPod is a stereo - not mono - plug, and that it is fully inserted into the HD500 cd/mp3 input jack. Also independently double check your headphones to make sure they are working properly, in stereo.
The analog cd/mp3 input signal is passed directly to the analog stereo outputs; it is not converted to a digital signal and it is not processed internally at all by the HD500. So there is very little chance that the HD500 is the problem. Certainly there is no HD500 configuration you can perform to resolve things. The only way the HD500 could be at fault is if there is a hardware problem in the cd/mp3 input jack or its internal routing circuitry. This is possible but not likely.
  • 1
.... John Lennon
#3 erickim
erickim
  • 2 posts
Posted 28 September 2013 - 04:43 PM
No luck still. I even switched out the cable. iPod is coming out stereo. I checked my headphone also. They all are working fine independently.
Thanks,
Eric
  • 1
#4 elchoco000
elchoco000
  • 2 posts
Posted 20 September 2015 - 06:10 PM
Hi, I have the exact same problem: in my headphones, ipad connected to cd/mp3 in only comes on the right ear, and guitar comes out on both ears.
its not a problem with cable, ipad, headphones
did you solve it?
thank you very much
francisco
#5 pianoguyy
pianoguyy
    Power User
  • PipPipPipPip
  • 2025 posts
  • Registered Products:2
Posted 21 September 2015 - 06:35 AM
Again, let's make sure that the cords are for audio and are in stereo.
Some of these newer units have mic and play/pause features that are designed for things like an iPod, but don't work for good old fashioned stereo.
And it sure would be nice if I could use 500edit on my Android Phone or Android Tablet to manage my Pod when not at home.
Even if it needs to be a '500 Lite' version that only allows for the import and export of patches, and not a full-fledged working program.
Something needs done.
#6 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1220 posts
  • LocationUK
  • Registered Products:6
Posted 21 September 2015 - 11:46 AM
and that the plugs is fully inserted...
and that the cable isn't faulty...
The 1/8 to 1/8 stereo leads are nearly the least reliable leads I have ever owned, the worst are the micro USB ones used to charge phones and tablets - basically the smaller the format the less metal and the quicker it breaks somewhere.
