Jlectka1 Posted July 20, 2017 Share Posted July 20, 2017 With my current guitar I run a dual cable with one output going to my pedal board and the other (piezo) going to a di box and then the pa. My question is: can I use the helix the same way, only with both outputs going into the helix and then the PA?? Or maybe just the acoustic patches to the PA and the electric to my amp? I'd like two just set up one button to handle my acoustic sound for the songs in my sets that need it. Can I even have the two cables out of my guitar go into two input plugs on the Helix LT ? If I can I'll likely buy one tomorrow. Quote Link to comment Share on other sites More sharing options...
ADBrown Posted August 8, 2017 Share Posted August 8, 2017 Yes this is possible with LT; plug your magnetic pickups into the guitar input and plug the piezo signal into one of the effect returns. You can set your input and outputs as you like; ex: Magnetic pickups are only sent out through 1/4" to your amp and the piezo is sent out through the XLR to the PA. You can also plug both into LT with LT going straight to the PA and assign a footswitch to switch between the two, or you can even blend them with LT. Quote Link to comment Share on other sites More sharing options...
