How Many Persons Rolled Back To A Before Hd Version?
112 replies to this topic
Poll: Version battles! (114 member(s) have cast votes)
How many roll back to a non HD version
  1. Roll Back (51 votes [44.74%] - View)
    Percentage of vote: 44.74%
  2. Stay on HD (63 votes [55.26%] - View)
    Percentage of vote: 55.26%
Vote Guests cannot vote
#101 smrybacki
smrybacki
    Iknowathingortwo
  • PipPip
  • 330 posts
  • LocationCarlisle, PA
Posted 16 January 2014 - 04:34 PM
Resurrecting an older thread...wondering if the folks that rolled back stayed or updated their firmware to 2.00?
Since I am relatively new to the Variax thing (Oct 2012) I don't really at this point see a need to rollback, so can anyone tell me WHY I might want to? :huh:
  • 1
#102 Charlie_Watt
Charlie_Watt
    Gear Head
  • PipPipPip
  • 814 posts
Posted 16 January 2014 - 05:44 PM
I'm with you.  Running 2.0 and not looking back.
  • 1
#103 johnnyayyy
johnnyayyy
    Power User
  • PipPipPipPip
  • 1364 posts
Posted 16 January 2014 - 09:21 PM
Some people think the pre-HD models sound better.
With all the problems people have had installing the HD firmware (some folks here ended up with bricked guitars) I really would not recommend making any changes up or down in firmware versions if you have a properly working JTV, at least not until Line6 works out the bugs.
  • 2
#104 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1095 posts
  • LocationUK
Posted 17 January 2014 - 01:45 AM
If the v2.0 firmware is working fine for you then there is no reason to roll back.
If you have never had experience with the pre-v2.0 releases then there is no comparison issue for you, so again, no reason to roll back, unless you are inquisitive and want to see for yourself what the pre-HD models sounded like, but be aware that the reflash process does not always go smoothly so if you try it ensure you do everything as recommended to minimise any risk of the operation fialing and having to be repeated numerous times.
If the v2.0 firmware has introduced a condition that you can't live with then you may want to roll back to a version without that condition. eg: for me it has introduced a loud popping noise when connected via VDI to HD500 and changing between patches that also force a model change on the JTV, this is not good for live use when changing patches mid song, so that has caused me to roll back to v1.9
For others, it has been the fact that you can no longer connect your JTV to workbench whilst connected to the HD500, you have to use the JTV USB dongle to connect to Workbench HD - that was loss of functionality which they considered important.
If you were accustomed to the model sounds from the earlier fw releases and had your live set tuned to those models, then the v2.0 models will cause you a problem because you will have to tweak everything to get back to something you like, and it may not be possible to reproduce exactly what you had because the actual model list has changed, some models have been replaced by other guitars with v2.0, plus well liked models like the Lester, Strat, Tele and Semi have been re-modelled possibly with different guitars and some now sound very different to the pre-v2.0 versions, so some people may try to tweak things to be more to their taste and may fail to get there, others may not want to be bothered, so to their ears the change has been "bad" and has not been an improvement as advertised and as expected by the HD association.  Some people had favourite models that were lost in the upgrade, so they had to choose whether to move on without those models or roll back to keep them.  For some, the new HD models were worth the sacrifice, but for others they were not.   Some people loved the new sounds immediately, others had to tweak them to get what they wanted, and others were met with what they thought sounded like "bad" and inferior model sounds, so moved straight back.
I think if the HD model set was a straight replacement for the pre-existing model set, just moving to better quality more realistic models of exactly the same guitars, then less people would have had issues. But the change was a combination of improved models possibly using different guitars, and completely new models nobody had before and losing some of the previous models.   Plus the actual installation of the fw is not always trouble free, even when following recommended instructions, so that puts people off immediately. Furthermore, there are known bugs that have still not been addressed.
Personally, I would like to move forward and stay on the latest and "greatest", but I have experienced the comparison "shock" in that the v2.0 HD models did not immediately live up to my expectations from hearing all the demo videos and in comparison to what I was accustomed to from my v1.71 model set, plus the confusion that the model list was not identical (not that I lost any favourite models, and not saying that some of the new models are not great additions to the selection, just that I had not realised it would be different), and I am frustrated by the inability to use Workbench HD when connected via my HD500, but the deal breaker was the fact that it introduced a loud popping sound when changing patches that forced model changes in the JTV from the HD500 when connected via VDI.    I am now back on v1.9 and have an open ticket with Line 6 support for the problem.  I am hoping they will address the issue, but given the fact that they have just been taken over by Yamaha, I am sure there are all sorts of things going off over there, and probably fixing bugs and releasing an update fw level is probably low on their list of priorities right now - which is a real shame.
Having said all of that, which I believe is a summary of all the issues I have seen reported, I am optimistic that these issues will be addressed in the fullness of time, I just wish they could fix them now!     :)
  • 5
#105 smrybacki
smrybacki
    Iknowathingortwo
  • PipPip
  • 330 posts
Posted 17 January 2014 - 03:26 AM
I wish I could give you a dozen reputation points for that incredibly helpful post. Thank you edstar1960 for summing that up so beautifully!
I did actually roll back to v1.19 for a while last night and played with my own favorite models (T-model, Spank, Lester, Chime) and also the acoustic models which have always seemed difficult to use effectively. I don't gig at present, but I am trying to pull together a solo looping act for open mics and such... Just because it is fun. I really didn't hear anything groundbreaking after about an hour or so, and so I rolled back without issue. Sounds like I am really glad I didn't hit any snags there. I haven't used the Variax workbench much, but when I did I was less than impressed by the process involved with the dongle thingie so if I get more involved with that, I may be tempted to roll back again. I have a POD HD500 as well, with a JTV59 but have had no popping issues.
Thanks again for the information, and if it isn't already stickied somewhere, perhaps it ought to be!
  • 1
#106 cruisinon2
cruisinon2
    Gear Head
  • PipPipPip
  • 511 posts
Posted 25 January 2014 - 04:49 PM
Apologies if this was already raised in this thread, but I'm too lazy to read thru 6 pages of posts to find out. I've been running 2.0 since the guitar came out of the box a month ago. Wanted to try an earlier version just for a comparison. Rolled back to 1.9, and without touching a blessed thing on the HD500X, right away I noticed a HUGE increase in sustain across most models, but particularly all the Lesters. Notes ring for days now....I like it. Anybody else notice this?
Also enjoying the lack of popping when switching patches on the 500x. Think I'm gonna leave it on 1.9 for a while. Acoustic models may not be quite as convincing as 2.0 versions, but not bad enough to make me switch back.
#107 snhirsch
snhirsch
    Iknowathingortwo
  • PipPip
  • 284 posts
  • LocationBurlington, VT USA
Posted 25 January 2014 - 05:25 PM
According to comments made by Line 6 when it was released, firmware 1.9 has the same HD acoustic models as 2.0.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990) w/ GK-3 Hex PU
James Tyler Variax JTV-69(k) w/ Strat Neck
Roland GR-55 Guitar Synth
QSC K10 FRFR
#108 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1035 posts
  • LocationGreece
Posted 25 January 2014 - 11:33 PM
Absolutely correct. The les paul had an awesome sustain, stratocaster also had longer than the 2.0 Version. I don't know what is the normal, though, but for sustain and some guitars is better the pre HD , I could say / choose the 1.71. for the acoustics. But since I have a variax of 1st gen, I keep my jtv on 2.0
#109 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1095 posts
  • LocationUK
Posted 26 January 2014 - 07:43 AM
Yes. The acoustic HD models were first introduced with 1.8. So the ones on 1.9 are the same as 2.0.
#110 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1095 posts
  • LocationUK
Posted 26 January 2014 - 07:47 AM
The HD acoustic models were first introduced with 1.8 so 1.9 versions should be the same as 2.0.
I have seen other people in other threads report sustain being far better on 1.9 than 2.0 for Lester and Strat models.
#111 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 14828 posts
  • LocationClemmons, NC USA
Posted 26 January 2014 - 07:55 AM
I think the fully implemented HD "engine" gave the models a little bump...
but they are indeed the same models as you've stated...
some people notice the difference, not quite as dramatic as 1.7 vs 1.8+
but not imagined either. :)
#112 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1095 posts
  • LocationUK
Posted 26 January 2014 - 08:01 AM
Thanks for pointing that out. Yes the new HD engine code must make a difference, and it may be subtle, but it must be there. Same models but upgraded engine code.
#113 Brazzy
Brazzy
    Iknowathingortwo
  • PipPip
  • 377 posts
I read many people went back to 1.9... But how many really?
I don't roll back I just move forward, Would only roll back if I had to get back to where I was.
  • 2
I mostly play at home and my own music which is more of a bluesy Jazzy Rock mixture as I'm still learning how to play guitar so when I post a reply to try and help give ideas you know where I'm coming from. In a nutshell I'm always learning and having fun doing it. Rock-On!! Oh, and if I don't respond promptly I'm probably playing guitar or my computer locked up from multitasking 'cause I'm using Gear Box, HD500 Edit, Audacity and tab filled browsers all at the same time, Hahahaaaa. Surprisingly enough my 'puter handles the load more times than not.
