Battery Conversion For Variax 500
variax 500 battery conversion battery lithium ion rechargable rechargeable batteries
7 replies to this topic
#1 Sumatra_Gold
Sumatra_Gold
  • 48 posts
  • Registered Products:3
Posted 24 September 2013 - 01:50 PM
First, let me apologize if this has been addressed elsewhere. I searched the forum for an answer to this question, but couldn't find one...hence this topic.
Basically, I'm wondering if a variax 500 can be upgraded to a rechargeable lithium ion battery like the JTVs. I own a JTV 89, which I love. However, I also have an opportunity to purchase a like new variax 500 for a song. I'm thinking the current battery situation with these old variaxes are an issue. Therefore, I won't purchase this guitar unless I can ascertain whether or not the current battery set up can be converted to the new rechargeable lithium power source as with the JTVs.
If this is feasible, please post any documentation, tips, tutorials, etc.
Thanks so much!
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 24 September 2013 - 01:54 PM
to my knowledge has never been done... should be possible.. however no official support obviously.
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 24 September 2013 - 03:30 PM
Yes it will work but there is one potentially serious problem.  Anything running on lithium batteries needs to have a reliable cutoff that prevents over discharging the battery.  It may cut off early enough.  The battery voltage is compatable.  I was thinking of doing this but I am reasonably satisfied with my 6 rechargables that I use now.  Same capacity as the JTV battery so it wouldn't run any longer with a JTV battery than it does with my NIMH rechargables.  The JTV must be much lower power because it runs much longer.
#4 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 24 September 2013 - 03:38 PM
I forgot another issue.  I looked into this myself and I could not find a battery box like the one on the JTV that would interface nicely with the battery and fit in the Variax 500.  That would be necessary unless you want to figure out a way to charge the battery in place.  Then you could hard wire it.  I don't recommend this though.
#5 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
  • Registered Products:4
Posted 24 September 2013 - 04:29 PM
To the OP, don't do it! The JTV batteries are expensive, and only last 2-3 years if maintained properly. If you leave the battery discharged for any extended period, there's a decent chance it'll be dead when you try to use it again. $50 more please.
I have 700's and I'll be leaving them the way they came so Line 6 can't keep putting their hand in my pocket. You can also get the power adapter from Line 6, or power it off a VDI cable into a POD HD500/X. My JTV59 is powered off my 700 power adapter so I don't have to keep forking out for batteries.
#6 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:2
Posted 25 September 2013 - 04:00 AM
I'm curious: Can the Variax power from the older XPS adapter?
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
Posted 25 September 2013 - 04:51 AM
yes, no problem at all.
#8 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 25 September 2013 - 09:21 AM
I mentioned this on another thread, but I'd really appreciate it if someone with a Variax (old or new) and an XPS supply would measure the DC voltage applied to the guitar while under load (guitar plugged in and electronics active).
Also tagged with one or more of these keywords: variax 500, battery conversion, battery, lithium ion, rechargable, rechargeable batteries
