Jtv-59 Model Selector Switch And Line6 Spare Parts
selector knob jtv-59
7 replies to this topic
#1 pheld
pheld
  • 37 posts
  • Registered Products:1
Posted 24 September 2013 - 10:59 PM
I just received a JTV-59 with a bad model selector switch (as replacement for one that was written off as unfixable). When pushed to switch between magnetic pickups and modeling the switch doesn't move equally well in all positions. In fact, it is just in the custom1-posistion that it reliably pops back out after being pressed. I've been looking for obstructions and not found any so it seems to be a problem inside the switch. I've also seen suggestions that problems with this switch may be caused by the knob being mounted to low on the shaft, but raising the position changes nothing. The switch does get stuck just as bad in the down position when operated with no knob on the shaft.
This may seem like a simple warranty case, but I'm reluctant to send the guitar back given my track record with the local distributor (Norway). The modelling circuit on my first JTV died after about a months use, and it took the distributor nearly 4 months to replace it. They spent almost 3 months diagnosing before finally reporting that they were unable to repair the guitar and had to order a replacement. This seems odd considering the modular construction of the instrument and that it should be e simple operation for anyone with a bit of insight to replace components one by one until the problem is solved. I'm not too keen on 4 more months without the instrument, so it leaves me with the following questions:
1. Is there something else I can try that won't affect the warranty, like electronics cleaning-fluid (isopropanol) or some form of lubrication on the switch.
2. Does line6 supply parts for these guitars at all? I can't see why the distributor would be unable to repair the guitar by swapping the electronics if they do have spares. It would otoh be problematic to maintain the guitar in the long term (when the warranty runs out) if there are no spares available. I haven't seen any 3rd-party rotary-switches on the market that would work as replacements for the model and tuning-selectors.
3. Is is possible for me to order the necessary parts to swap out the main selector myself so that I won't have to be without an instrument for months? I can't get a straight answer from the distributor. I do understand that l6 may not want people to buy complete electronics kits to install in other instruments, but individual parts must at least be available somehow.
#2 toasterdude
toasterdude
    Gear Head
  • PipPipPip
  • 974 posts
  • Locationsanto domingo
  • Registered Products:10
Posted 25 September 2013 - 07:46 PM
I hope so. Heck I even want to buy some pots because I don't like the gold/yellow/brown pots that come on 59s. I would rather have chrome, even black.
#3 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
  • Registered Products:4
Posted 25 September 2013 - 10:16 PM
Unfortunately, Line 6 uses a lot of custom parts for these switches and potentiometers. The only way to get this fixed is to get a Line 6 repairer to do it. There are essentially no spare parts available for the JTVs (apat from batteries, etc.), and your normal electronics shops don't carry these specialised parts.
Sorry to be the bearer of bad news. You should be able to convince your repairer to get the part in rather than hold onto your guitar for 3 months however.
#4 pheld
pheld
  • 37 posts
Posted 26 September 2013 - 09:13 AM
I didn't ask for genuine parts to be carried by the local hobbystore. I'm requesting spare parts from Line6. The repairer in my case is the national distributor of line6 products. If they can't handle it I'd have to ship the guitar abroad, and then we're looking at repair-costs of $500-1000 or even more for an instrument that was broken as it left the factory.
#5 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
Posted 26 September 2013 - 09:36 AM
As I said, Line 6 doesn't sell spare parts, apart from those available in the online store (batteries, etc.) Your local Line 6 repairer can order in whatever parts they need, but you have no direct access to these. The only way to get this JTV repaired is to go through your Line 6 repairer unfortunately.
#6 pheld
pheld
  • 37 posts
Posted 26 September 2013 - 09:46 AM
If they want to be that restrictive maybe L6 should act responsibly and find a distributor for their products that offer decent service. In my country they've made the worst possible choice and most people I know avoid all products (not just l6) handled by this distributor. When my 3rd JTV-59 arrives 4 months from now I will have enjoyed playing the instrument for 4 weeks in 9 months. That hardly counts as a recommendation to potential buyers.
#7 Kotrach
Kotrach
  • 2 posts
  • Registered Products:2
Posted 21 March 2016 - 06:57 AM
I know this thread is old but I got here with the same problem... and found the solution (for anyone with the same problem)
http://www.fullcompa...ne-6-50-02-9331
#8 Indianrock2020
Indianrock2020
    Iknowathingortwo
  • PipPip
  • 442 posts
  • LocationBellingham, WA
  • Registered Products:3
Posted 26 March 2016 - 04:43 AM
Nice except that is a pickup selector switch and the OP was asking about
"...JTV-59 with a bad model selector switch (as replacement for one that was written off as unfixable). When pushed to switch between magnetic pickups and modeling the switch doesn't move equally well in all positions. In fact, it is just in the custom1-posistion that it reliably pops back out after being pressed"
