'effects Loop' Hd500 Into Dt25
5 replies to this topic
#1 oehman
oehman
    Iknowathingortwo
  • PipPip
  • 161 posts
  • Registered Products:4
Posted 25 September 2013 - 08:57 AM
Took the plunge and bought a DT25 yesterday!
When hooking up the HD500 via L6 link, how are the effects processed in the DT25?
Are effects placed after the amp block treated as if they are part of the effects loop of the amp?
Is this sort of like a Four Cable Method, but with just 2 cables?
#2 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5288 posts
  • Registered Products:6
Posted 25 September 2013 - 09:19 AM
WYSIWYG in terms of the chain in the HD500....The DT25 FX Loop is after the HD500 chain...So effects are where-ever the are relative to the amp block in the HD500...audio is one way in the link...
#3 oehman
oehman
    Iknowathingortwo
  • PipPip
  • 161 posts
Posted 25 September 2013 - 12:20 PM
So if reverb or delay effects are placed after the amp block and mixer on the 500HD, they sound the same as if they were in the effects loop of the DT25 effects loop?
#4 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5288 posts
Posted 25 September 2013 - 05:46 PM
As long as the HD500 amp block is enabled, the chain order is exactly as it looks i the HD500...
#5 sorced
sorced
  • 2 posts
  • Registered Products:2
Posted 20 May 2014 - 02:43 AM
When you switch from chA to chB using your POD. What happens with the signal chain?
You still hear the effects programmed in chA but with a different output?
You allmost can´t use teh same echo or reverb when switchib channels.
I´d like to have same effect-settings on both channels. chA would be my solo-channel and
chB my rythm-channel.
#6 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 20 May 2014 - 09:12 PM
Yes, and they are placed prior to the actual fx loop. Guitar->pod effects->amp block->pod fx->line6 link->dt master vol->dt fx loop->dt power amp.
Note that the use of cab models and lvm may possibly change or add processing in the dt, this is a bit unclear.
