Mozolewski Posted August 7, 2017 Share Posted August 7, 2017 Hello guys! Can someone tell me how can I connect SDRUM to HD500X? SDRUM input is mono, so if I put it at the end of chain I will lost all stereo effects of reverb effect from POD. If I put it in front, then the reverb effect will affect drums as well. How to do this correctly? Also SDRUM gives stereo output but I'm not sure if it's correct to MIXER OUT to POD FX RETURN. look at this link for explanation: https://3e7777c294b9bcaa5486-bc95634e606bab3d0a267a5a7901c44d.ssl.cf2.rackcdn.com/product_documents/documents/5521_1494359729/SDRUM_Quick_Start_5086300-A_original.pdf Quote Link to comment Share on other sites More sharing options...
Brazzy Posted August 8, 2017 Share Posted August 8, 2017 I would try taking the pods FX loop send into the sdrum and out the sdrums stereo into the pods fx loop stereo. Quote Link to comment Share on other sites More sharing options...
Mozolewski Posted August 8, 2017 Author Share Posted August 8, 2017 @Brazzy this is good idea but my concern is if FXloop is the last one in effects chain than I will lost all stereo effects because SDRUN has mono input, so all kind of stereo reverbs added to the guitar tone will gone. What do you think? Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 8, 2017 Share Posted August 8, 2017 I would try a slpitter box and send your guitar signal to both the SDRUM and POD HD and send the mixer out(s) of the SDRUM to the POD's Aux cd/mp3 in. Quote Link to comment Share on other sites More sharing options...
Mozolewski Posted August 8, 2017 Author Share Posted August 8, 2017 SDRUM manufacture have informed me that if I use both AMP OUT and MIXER OUT, in amp I will receive only guitar signal and on mixer out drums only. So, there is another solution with the same cost and even lower (at least in my country): Connect SDRUM before POD and connect mixer out to mixer together with POD unbalanced output - mix them and send to amplifier. Mixer will give you much more control and, in my opinion, this type of connection is more pro. 1 Quote Link to comment Share on other sites More sharing options...
