mr34h7jm Posted August 9, 2017 Share Posted August 9, 2017 Hello all, I have an MKII shortboard that I'm trying to use the expression pedal for wah. Also, I have a Mission Engineering EP1-L6 expression pedal I want to use for volume. In HD Edit the shortboard wah pedal has an FS ASSIGN of EXP TOE SWITCH and the controller is EXP-1. The Mission pedal has an FS ASSIGN of NONE and the controller is EXP-2. The Mission pedal keeps randomly disconnecting from the MKII (and HD Edit). I can plug it into the MKII and both the red wah and green volume led lights are lit indicating the mission pedal is connected, but as soon as I step on the wah the Mission pedal disconnects. It has disconnected from just rocking the wah. I made sure I saved the preset. I don't know what else it could be, I'm hoping I just have the settings wrong. Going bonkers here, any help will be greatly appreciated. Edit: I'm connecting to a POD HD PRO X. (Flash Firmware 2.62, USB FW 1.04) Quote Link to comment Share on other sites More sharing options...
mr34h7jm Posted August 11, 2017 Author Share Posted August 11, 2017 Update - I can use the MKII and Mission pedal without any issues connected to my POD HD bean. The Flash Firmware for the Bean is 2.62, USB FW is 1.04. I reset my PRO X by holding down the left Nav. arrow while powering on, I have Input 1/Channel A panned center and Input source 2 mic. I recalibrated the MKII and the mission pedal still disconnects. Do I need to assign the mission pedal settings in the MIDI assign section under controllers in HD Edit? Is the Issue with the PRO X being defective? Again, any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
