Can I mix a L3T with a L2T or L2M?
4 replies to this topic
#1 slhess
slhess
  • 3 posts
  • Registered Products:7
Posted 11 August 2017 - 11:11 AM
I have a L3T. Can I use it as a master with a L2T or L2M?
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 12 August 2017 - 04:41 AM
Not sure what you mean by "use it as a master". Explain?
.... John Lennon
#3 slhess
slhess
  • 3 posts
Posted 12 August 2017 - 09:50 AM
The L3T would be the master and the controlling mixer as it would all be connected to the L2T or L2M via L6 link. I'm using L6 link from a Helix LT to the L3T. So it's all a digital connection.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
Posted 13 August 2017 - 04:43 AM
That setup would work best if you connect the Helix LT to the L3t using its rear panel analog connections rather than using L6 Link. Use the L6 Link connections to connect the two speakers together in a 2-way L6 Link connection - the OUT of each speaker to the IN of the other. That way you can use the side panel mixers and all inputs of both the L3t and the L2t/m and all inputs will be routed properly in stereo to both speakers. There is no need for a 'master' speaker.
Connecting the Helix to the L3t via L6 Link means no inputs from the L2t/m speaker can be routed to the L3t speaker because its L6 Link IN connection is already in use.
  • 1
.... John Lennon
#5 slhess
slhess
  • 3 posts
Posted 13 August 2017 - 11:18 AM
OK Thanks.. That sounds good. I really want to add a additional speaker so I wanted to know about the compatibility between the L3T and L2 series speakers when using the L6 link. Stereo is what I'm shooting for.  The reason for using the L6 between the Helix LT and L3T is to leave the 1/4' and XLR jacks free. I am currently routing the XLRs to a mixer for recording. with the 1/4 jacks left open I can use them for a dry outputs to an amp or amps and the speakers on the L6 link stereo wet. so I'd have a wet dry wet stereo set up.
