Crackling static noise
20 replies to this topic
#1 jorgealberto25
jorgealberto25
  • 11 posts
Posted 17 August 2017 - 05:21 PM
Hi guys i have this noise problem with helix native. Is like crackling static noise when i palm mute. But it only happens with certain amps.it all happen when i downloaded ola englunds 5150 patch. Idk but this is wierd, if i use and od pedal and a noise gate and nothing else the noise is gone like 90% but if i use eq pedals racks and such like on the patch the noise is back!
Im using a scarlett studio first gen with unbalanced output, Daw is studio one 3 and logitech z623 speakers.
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7366 posts
  • Registered Products:6
Posted 18 August 2017 - 04:49 AM
Did you try adjusting the level coming into the plug-in?
#3 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 07:13 AM
All levels are fine. its wierd on my 6 string, if i turn the tone knob off the noise is gone. on the 7 is not that bad but its sound muddy. i tried a real amp to see if it was the pickups. and no noise, the 7 string sounded good like it was alive lol.
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7366 posts
Posted 18 August 2017 - 07:33 AM
Can you post a sample?
#5 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 08:22 AM
#6 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 08:23 AM
tone knob on, on the 6 string.
on the 7th you could barely hear it. and still annoying lol. but the low end sounds muddy.
#7 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 11:31 AM
idk if you guys wanna try the rhythm presets and see if its my gear or the presets. thanks
https://feared.wetra...16103023/060340
#8 Malibu1328
Malibu1328
  • 3 posts
  • Registered Products:1
Posted 18 August 2017 - 12:30 PM
I am also getting a bunch of static on Helix Native.
I know in Guitar Rig 5 I can eliminate that static with the Gate nob at the top.
I also have the Helix Rack and don't get the static sound.
Thanks in advance.
#9 ChaosNone
ChaosNone
  • 56 posts
  • Registered Products:3
Posted 18 August 2017 - 02:30 PM
So I found what the issue is. Apparently this plugin is not multithreaded. I have a new i7 and this plugin maxes the processor when your patch has a lot of low end. I was using sonar and you can see the first core of the i7 processor max out and start crackling. This is very noticeable with the sandman patch on the 2nd play list. L6 please make this processor multi core supported and fix the low end maxing the processor. Something that helped me was cut the low end frequency in your patch. Other than this the plug in sounds great!
#10 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 07:44 PM
Thanks in advance.
yeah, same with Amplitube it works fine. what interface are you using?
#11 jorgealberto25
jorgealberto25
  • 11 posts
Posted 18 August 2017 - 08:04 PM
Thanks in advance.
wow so that is the issue. thanks for the help! i hope u can help me with this other thing i know is not line 6 related. but i have bought their gear lol. anyways i have two guitars one ibanez and one jackson. both sound great on my peavey vypyr amp. but on amplitube is different. you know that metallic aggressive tone we get when we palm mute power chords ( ola englund type, metallica etc..) ? well with the ibanez it seems i cant achieve it on amplitube when theres allot of low end and its been equalized by others.( its a patch a downloaded from youtube) to much bass and noise that i have to make my own adjustments and problem solved. but its wierd that both can manage the tone pretty well on the vypyr and that the ibanez cant on amplitube with amps being equalized differently. could it be my pickups that cant manage well the low end or something, or the interface? thanks
#12 DogsoverLava
DogsoverLava
  • 2 posts
Posted 19 August 2017 - 09:36 AM
I'm getting this same static issue on my rig --- and all the usual suspects have been checked and this is not related to my gear.  Not sure what the issue is - I have an older i7 -- boatloads of RAM -- running Reaper ---- Can run GuitarRig and Amplitube and every plugin known to man simultaneously without any issues -- a single instance of NATIVE and I get load grade static and crackle on all the sounds.
#13 jorgealberto25
jorgealberto25
  • 11 posts
Posted 20 August 2017 - 09:41 AM
Yeap line 6 should fix that issue. Good thing that i only downloaded the trail. I was about to buy the full version.
#14 GilmourD
GilmourD
  • 22 posts
Posted 20 August 2017 - 09:49 AM
I've got the crackling issue on my box, too. It seems to have lessened when I changed some clock settings in my BIOS (run at max clock all the time instead of throttling, although that still seems to not actually be happening). No individual core seems to be maxing out. I toggled between Helix and Pod Farm 2 to make sure it wasn't a newly occurring hardware issue or something but PF2 is OK.
Running in the latest Reaper.
My rig is:
Desktop: [Processor: Intel Skylake i5 6600K (stock for now)][HSF: CoolerMaster Hyper 212 EVO]
[PSU: EVGA SuperNova 750 B2][Case: Corsair Carbide Series Air 540 Silver]
[Motherboard: AsRock Z170 Extreme4][RAM: 2x8GB Corsair Vengeance LPX DDR4-2666]
[Video: eVGA GeForce GTX 560 Ti DS Superclocked 01G-P3-1567-KR]
[Hard Drives: Samsung 850 EVO 500GB]
All that said, damn, these tones are nice.
#15 Torray654
Torray654
  • 1 posts
  • Registered Products:2
Posted 01 November 2017 - 04:16 PM
Having the same issue here, popping and clicking noises, on every pre-set I have tried, crunch, clean, etc... I do not have this issue with any other pluggin I am using. I have Pro-tools 12. plenty of processor, ram, blah, blah, blah.
#16 robvde
robvde
  • 2 posts
  • Registered Products:4
Posted 20 January 2018 - 08:18 PM
I have the same issue here with Reason 10. Moved audio interface from Asio4All to a native Asio driver but that didnt solve it. The only thing that seems to help is to increase the amount of samples in the buffer even up to a point where with a "smaller" buffer size the playback of a song slows down. This all happens as soon as i enable the helix native effect, switching off the effect in Reason brings it all back to a normal state.
I'm using the latest Lenovo Yoga, i7 and 16GB. Interfaces tried: Shure MVi with Asio4All drivers and the Roland Duo Capture MKii with native Asio drivers.
Any suggestions are welcome but  at this point the Helix Native is pretty much useless .
#17 soundog
soundog
    Iknowathingortwo
  • PipPip
  • 477 posts
Posted 25 January 2018 - 10:00 AM
Hopefully this gets fixed soon for us folks. I've used early versions of various plug-ins that had issues with CPU and system audio, and they were soon ironed out by the developer in a subsequent release. So I'm hopeful...
#18 FortyPsi
FortyPsi
  • 7 posts
Posted 29 January 2018 - 12:25 AM
I had exactly the same problem.  It was completely unusable.  Cracking, spluttering fizzing and popping.
I did a little searching on latency and found various ways to detect problems within my system.
I can't remember which free latency check programme I used but it identified a few areas of concern.
Then I read that power saving plans can schedule operations and this could cause latency issues.  I changed my power settings from Balanced to Maximum performance.
The Latency check program reported that my system was now fine and Native now runs perfectly with a lot less CPU usage.
So it may be worth checking your power plans.
If that fails try one of the free latency detection programs and it hopefully it be able to tell you what is interrupting the process.
An i7 if far more than capable of running Helix Native.
It runs fine on my i3 with 4 gig or ram.
Sorry if I'm teaching you to suck eggs.  I hope this helps.
  • 1
#19 soundog
soundog
    Iknowathingortwo
  • PipPip
  • 477 posts
Posted 29 January 2018 - 09:24 AM
On a related topic ....  i recently started recording new projects (Logic Pro X) at 88.2 KHz, 24 bits bits (used to use 44.1 KHz). I started having problems with crackling and midi/audio synch. This is on a newer, potent computer with lotsa RAM. After reading some white papers showing experienced listeners often couldn't distinguish differences between 88.2 and 44.1, 24-bit classical recordings, I've gone back to 44.1 KHz, 24 bits and things have improved. Interestingly, many sample-based VI's work better at 44.1 anyway.
I don't want to start a debate about 44.1 v 88.2 v 96 KHz, but there are complex decisions to be made these days (sample rates, CPU, chip set, RAM, DAW, CPU-hungry plug-ins like Helix, audio interface, hard drive speeds, on and on). Trade-offs have to be weighed. The last thing I want to do is reset buffer sizes or freeze tracks when I'm heads down in a mixing session.
#20 Lachdanan0121
Lachdanan0121
    Gear Head
  • PipPipPip
  • 624 posts
Posted 30 January 2018 - 06:44 AM
Not debating, as you are correct. Just including below why you are correct.
For end user listening 44.1khz is plenty. It encompasses the entirety of human hearing.
Humans hear in the 20hz to 20khz range, though as you get older, and depending on environment, as you become an adult that is reduced down to about 17khz.
The 44.1khz has a freq range of 1hz to 22.05khz. That encompasses the entirety of human hearing including babies, and children. Anything more would only be noticeable in the studio with expensive high-quality equipment, and there is a large chance it won't be that noticeable even there.
Also 12bit was cassette. 16bit was CD. 16bit is plenty for consumer audio. The only real benefit to 24bit, 32bit float, (or higher) is more headroom in the mix (in the studio) when the mixing/mastering engineers are still working on the project. When they get finished it will be out at 16bit, 44.1khz on a disc.
Bellum Ex Deus, Intellectus Ex Scientia.
Belief is in no way an adequate substitution for understanding.
#21 soundog
soundog
    Iknowathingortwo
  • PipPip
  • 477 posts
Posted 30 January 2018 - 09:44 PM
...thanks for all the interesting data; it gives me more confidence in going back to 44.1 kHz. And it gives me more disk space!
