Digital-sound Posted September 27, 2013 Share Posted September 27, 2013 I am not sure if this is a result of the new firmware, or was there before, or is something I did. I was playing around with the presets. I was loading the vocal presets with effects on them. I had the effects tweak page loaded on my vocal channel. When I loaded the "male vocal reverb", the reverb knob went up, and all other effects down. When I then loaded the "male vocal doubled" preset, the doubler knob went up and all others down. When I loaded the "male vocal delay" preset, ALL the knobs went down to nothing. No effect. I would have expected the "delay" effect to go up. Can someone check their board and see if it is the same? Clearly this is not much of an issue. Just a possible "bug"? Or, maybe I have done something along the way. I backed up and restored my settings. Maybe sometime ago I overwrote the setting after turning the effect off. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted September 27, 2013 Share Posted September 27, 2013 The effect send settings are stored with the preset. When you are on the fx tweak page you see all fx sends for that channel. The changes you see apply only for the channel you are seeing since only the fx sends are recalled. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted September 27, 2013 Author Share Posted September 27, 2013 What I am doing exactly, is double tapping my vocal channel knob, and going to the effects "tweak" page. When I load the preset "male reverb", the reverb setting goes to about -20db. When I load "male delayed" I would expect they"delay" effect to be added, but all the effect knobs remain (or move) all the way to the right (off). There is no delay on my voice when I load "male delayed". As I said, maybe I overwrote the preset, but thought someone else could verify that delay is indeed added when "male delayed" is loaded. Coincidentally, it is the same for the "female delayed". No delay is added. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted September 27, 2013 Share Posted September 27, 2013 Now I got it. The "male delayed" has a delay fx in the DSP chain and does not use the global delay fx. When you are in the tweak page of the "male delayed" preset you will see a tab "echo" (quick tweak) or "delay" (deep tweak) Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted September 28, 2013 Author Share Posted September 28, 2013 Ok. I was not listening when I did this so of course did not hear effect. I was just looking. Thanks for the information. I feel bad as that is almost worse than not reading a manual! My "audio" board doesn't "look" right! Doh! Quote Link to comment Share on other sites More sharing options...
