Line 6 Monkey V 1.65 Hanging
monkey searching for devices
4 replies to this topic
#1 rkraus10
rkraus10
  • 1 posts
  • Registered Products:3
Posted 28 September 2013 - 08:48 AM
I recently launched the monkey and it prompted me to install the new version 1.65
It hangs when searching for devices.
Line 6 edit works fine with my POD XT Live.
#2 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 28 September 2013 - 08:55 AM
Download Monkey directly from here http://line6.com/software and do the install.  You might have more success.  Sometimes installing software from inside of Monkey doesn't work well.
#3 matachi21
matachi21
  • 2 posts
  • Registered Products:1
Posted 02 April 2015 - 12:30 PM
I am reposting my answer below here, seems to be same issue reported twice:
I had the same problem with Monkey 1.70 hanging on start-up in "Detecting MIDI devices" phase. I did some trial and error tests, is definitely a bug (or incompatibility) in Monkey. I use WindowsXP still. It does not like USB audio devices. If you plug one in I am guessing it messes up some Monkey data cache or some windows registry settings. It will make Monkey scan for MIDI and hang. Removing the USB device will not help, once the harm is done, is permanent.
The only way I found to fix this is to uninstall Monkey then install first an older version (Monkey 1.33 from GearBox package). Version 1.33 is too old to use, it gives some server connectivity error (I think the client-server communication protocol was changed, cannot even login with 1.33), but it will not scan MIDI and will detect correctly the Line6 USB device, also I guess in the background restore settings for it in registry or whatever data cache.
If you then leave the Line6 USB device connected and just install Monkey 1.70 over the old version, it will work. It will start normally and skip the MIDI scan.
Here are the detailed steps tested by me:
Programs -> Line 6 -> Tools -> Line6 uninstaller - uninstall only Monkey 1.70
Disconnect any USB audio device. You can leave connected USB storage devices like an HDD.
Run GearBox 3.72 installer - install only Monkey (version 1.33)
connect the POD Live X3 or whatever when the installer asks for it.
Start Monkey 1.33 and try to connect to server (Note: it will ask as option to scan MIDI devices if device is not connected, but you should have the device connected in which case it will skip over MIDI scan).
Let it configure the POD device.
Do not allow to upgrade to new Monkey version
Close Monkey 1.33 and run the new Monkey 1.7 installer while device is connected to USB port. Run Monkey at the end of installation, it will not scan MIDI this time, it will work.
#4 enjhi
enjhi
  • 1 posts
Posted 08 April 2015 - 06:38 PM
Hi guys, I bought hd500x and install monkey with the hd500 edit in pc (core i3 8Go ram - win 7) and it's working well. Now, I install it in my own laptop and the line6 monkey can't connect to internet when I enter the same login and password as before.
So, now I can't use hd500x edit without getting the driver from monkey. Anyone have any issue?
I already disable antivirus, recheck my internet connexion but nothing.
Thnks
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7362 posts
  • Registered Products:6
Posted 09 April 2015 - 07:02 AM
You could try downloading and running the driver installer outside of Monkey.
Also tagged with one or more of these keywords: monkey, searching for devices
