abcdrecorpse Posted September 14, 2017 Share Posted September 14, 2017 Hi. Native have only 5 User folders for presets. But i have lot presets and i need create 2-3 folders. How it create? Quote Link to comment Share on other sites More sharing options...
soundhog Posted September 14, 2017 Share Posted September 14, 2017 Helix Native's Preset Library includes 8 Setlists, and as you mention, 5 of them are empty and available for your own presets. You can also overwrite any of the presets within the Factory 1, Factory 2 or Templates setlists if you like. Note that you can also backup each Setlist by using the Export Setlist feature in the plug-in's Preset panel. So, if you need more storage, you can Export one of your full Setlists, which copies it to your hard drive. Then you can clear out the Setlist that you backed up and fill it up again, creating a new Setlist. You can still have only 8 Setlists within the Library at one time, but at least this way you can Import any Setlist that you Exported to use it. Or, Note that you can also use the File > Save To Disc feature (from the FILE menu at the top of the Signal Flow) and this saves your current Signal Flow tone as an individual preset to your hard drive (and not within the plug-in's Preset Library). You can save as many presets as you like this way, and then just use File > Open From Disk to load any of these saved presets. You can organize these presets however you like on your hard drive. Hope that helps! 1 Quote Link to comment Share on other sites More sharing options...
abcdrecorpse Posted September 14, 2017 Author Share Posted September 14, 2017 to soundhog Big thanks for best answer! Quote Link to comment Share on other sites More sharing options...
