I Hear When I Connect The Microphone To The Mic In Of My Hd 500?
mic in
Best Answer guillermohaad , 30 September 2013 - 10:59 AM
ok thank you by you help.. go to learning..
Go to the full post
11 replies to this topic
#1 guillermohaad
guillermohaad
  • 8 posts
Posted 30 September 2013 - 08:49 AM
Hi,  I don't Speaking Inglish , I speak spanish..
I don´t hear when I connect the microphone to the MIC IN of my HD 500 I should do ? :(
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15910 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 30 September 2013 - 08:51 AM
Make sure your HD500 preset is set to use MIC as an input.
Adjust the Mic Trim knob on the rear panel of your HD500.
  • 1
.... John Lennon
#3 guillermohaad
guillermohaad
  • 8 posts
Posted 30 September 2013 - 09:21 AM
I do these two steps or simply moving the knob?
than you
#4 guillermohaad
guillermohaad
  • 8 posts
Posted 30 September 2013 - 09:25 AM
how I do this?  Make sure your HD500 preset is set to use MIC as an input.
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15910 posts
Posted 30 September 2013 - 10:43 AM
Every HD500 preset has 2 selectable Input sources. See Setup page 3 - Input Options.
Here is the Spanish manual. You should read it.
http://line6.com/dat...h ( Rev A ).pdf
  • 1
.... John Lennon
#6 guillermohaad
guillermohaad
  • 8 posts
Posted 30 September 2013 - 10:59 AM   Best Answer
#7 guillermohaad
guillermohaad
  • 8 posts
Posted 30 September 2013 - 02:10 PM
silverhead
I want to connect to the MIC input XLR of Pod HD 500 a microphone SHURE high but this Setup page 3 - Input Options does not say how to configure?
#8 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15910 posts
Posted 30 September 2013 - 02:25 PM
First, you need to be using a dynamic mic. The HD500 does not provide the phantom power that a condenser microphone needs.
On the Input Options page, you need to rotate the associated black knob beneath the display to change the parameter settings. Make sure the Inputs Setup is set to PRESET (knob/parameter #4). Then make sure one of the Input Sources (knobs 1 and 2) is set to MIC. Then adjust the Mic Trim knob beside the Mic XLR input until you can hear the microphone input. Then assign your desired amp/FX to the signal path(s).
  • 1
.... John Lennon
#9 guillermohaad
guillermohaad
  • 8 posts
Posted 01 October 2013 - 05:08 AM
Thank you silverhead
so I can sing and play guitar at the same time?
#10 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15910 posts
Posted 01 October 2013 - 06:01 AM
Yes - but you need to set up your preset carefully to keep the signal paths completely separate. Here's a preset I made some time ago that you can use as an example of how to set the signal paths:
http://line6.com/cus...ne/tone/215659/
Adjust the two paths to your taste in terms of amp/FX processing.
  • 1
.... John Lennon
#11 guillermohaad
guillermohaad
  • 8 posts
Posted 01 October 2013 - 06:44 AM
silverhead this document http://line6.com/cus...ne/tone/215659/   I can't I can not see my e-mail is: guillermohaad@hotmail.com
thank you
#12 guillermohaad
guillermohaad
  • 8 posts
Posted 02 October 2013 - 04:56 AM
thank you Silverhead,
Thanks I was able to use the microphone, but it sounds with echo effect as I can remove?
