Trouble In Expression Pedal
pod hd 500 expression pedal volume pedal wah
2 replies to this topic
#1 delanoamaral
delanoamaral
  • 6 posts
  • Registered Products:1
Posted 30 September 2013 - 10:01 AM
Hello folks...
Here I am again facing trouble in my POD HD 500. I've just had problem in USB data transmission and a flashing Line 6 logo. I managed to solve it with some help from the forum, but now de expression pedal is not working. Even in the factory presets. It just turns ON or OFF the effect (Wah or Volume Pedal) but dont change the parameter. The Wah satys only in the OPEN position, and the Volume stays only opened too.
Did someone face this trouble before? What have you done?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9059 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 30 September 2013 - 10:03 AM
Try recalibrating the pedal: http://line6.com/sup...alibration-r161
#3 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 30 September 2013 - 10:38 AM
After reflashing the firmware (which I believe you did to resolve the flashing logo issue) you should also reset the global parameters.
http://line6.com/com...y/docs/DOC-2222
.... John Lennon
Also tagged with one or more of these keywords: pod hd 500, expression pedal, volume pedal, wah
