wkdsoul Posted October 10, 2017 Share Posted October 10, 2017 Ok that was weird, post was blank....Hi, Sorry if this is a dumb question not used this in forever. I record a 2 mic setup into Reaper (separate tracks) . I usually record dry input, and use the reaper effects later. Can i use the pod farm effects on an already recorded track? or is it either or, as i only have the 2 inputs? sorry if that doesn't make sense. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 10, 2017 Share Posted October 10, 2017 If you have POD Farm 2, the answer is yes because you have the plug-in license also. The plug-in is launched within Reaper Also, if you have the UX, you have up to 4 available outputs for Reaper. These can be configured in the PF (standalone) mixer view. A typical workflow is to capture the wet and dry signals simultaneously and add the plug-in to the dry track. Quote Link to comment Share on other sites More sharing options...
wkdsoul Posted October 12, 2017 Author Share Posted October 12, 2017 If you have POD Farm 2, the answer is yes because you have the plug-in license also. The plug-in is launched within Reaper Also, if you have the UX, you have up to 4 available outputs for Reaper. These can be configured in the PF (standalone) mixer view. A typical workflow is to capture the wet and dry signals simultaneously and add the plug-in to the dry track. Quote Link to comment Share on other sites More sharing options...
wkdsoul Posted October 18, 2017 Author Share Posted October 18, 2017 Figured this out, im an idiot :) Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 18, 2017 Share Posted October 18, 2017 If you're an idiot then how did you figure it out!!?? :lol: :lol: :lol: 1 Quote Link to comment Share on other sites More sharing options...
