cibob476 Posted October 20, 2017 Share Posted October 20, 2017 greeting all, i'm cibob from indonesia..as we all know, hd500x had ton of effect/amp sim..is there a way to delete/hide effect/amp that we're not using/want it?i feel disturbed had to turn the knob so many time every time.. LOLespecially after i bought the full bundle.. :Dthank's for your reply.. Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 20, 2017 Share Posted October 20, 2017 No - there's no way to do that. 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted October 20, 2017 Share Posted October 20, 2017 If you use the editor for creating presets, it might be possible to edit the 'PODX4Edit.lang' file, located in the 'res' folder wherever you have hd500x edit installed. It's just a text file and when you look at the contents it should be obvious which entries you would want to change. Most likely you'd want to replace the offending amps with a blank ("") text description. The resulting list would still be the same length, but with some empty entries, making the amps (or effects) you want slightly easier to locate. You may even be able to delete the entries you don't want, however I'm uncertain what that would do. If you don't use the editor, then as silverhead said, there'd be no way. 1 Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted October 21, 2017 Share Posted October 21, 2017 it might be possible to edit the 'PODX4Edit.lang' file, No, it isn't. At least no when I tried, time ago, to replace L6 amp names with real ones. It would have been great to be able to do it, though 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted October 21, 2017 Share Posted October 21, 2017 No, it isn't. At least no when I tried, time ago, to replace L6 amp names with real ones. It would have been great to be able to do it, though Just quickly tried, editor v2.26.0, and it did indeed work, both with the HD turned on and off. And completely deleting an entry leaves behind a blank entry in its place. 2 Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted October 21, 2017 Share Posted October 21, 2017 Just quickly tried, editor v2.26.0, and it did indeed work, both with the HD turned on and off. And completely deleting an entry leaves behind a blank entry in its place. Great! I have finally been able to rename the amps!! My amps are now properly named ( Roland JC-120, Fender, Gibson... ) Thank you, sir! 1 Quote Link to comment Share on other sites More sharing options...
cibob476 Posted October 23, 2017 Author Share Posted October 23, 2017 thank's to all for your reply.. Quote Link to comment Share on other sites More sharing options...
