Blocked Footswitches (pod Hd 500)
footswitches
10 replies to this topic
#1 Finalchimera
Finalchimera
  • 11 posts
  • Registered Products:2
Posted 02 October 2013 - 10:51 AM
Hey guys !
I have a little problem and I don't understand its origin :
When I use the looper, I can record my loop and right after that all my footswitches are blocked except for the 7th and the 8th footswitches.
I didn't have that problem a few weeks ago, I updated my firmware, drivers, ...
Moreover, the first time it happened to me I switched my HD 500 off and on which settled it.
But it doesn't work anymore !
Maybe I should try to reset the pedal?
I prefer to ask before doing something wrong !
Thanks a lot !
Finalchimera
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 02 October 2013 - 03:47 PM
i say re-flash the firmware do a global reset and cal the pedal
  • 1
I'M SO HAPPY!
#3 Finalchimera
Finalchimera
  • 11 posts
Posted 03 October 2013 - 07:46 AM
Hey Guru thanks for this piece of advice !
I did what you said and it seems to work fine for the moment :D
Thanks a lot !
Cheers !
Finalchimera
#4 Finalchimera
Finalchimera
  • 11 posts
Posted 07 October 2013 - 11:54 AM
Hey Guru !
The problem occured again, I reflashed the POD HD500 and it still happens.
I guess it must be a hardware problem then... :/
What do you think?
Finalchimera
  • 1
#5 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 07 October 2013 - 12:39 PM
Crack it open and check your ribbon cables. Something may be loose or damaged. If it only happens when in looper mode, I would say hardware defect, especially if the reflash/reset/recal didn't fix it.
  • 1
#6 Finalchimera
Finalchimera
  • 11 posts
Posted 07 October 2013 - 08:24 PM
Hey Iknowathingortwo !
Thanks for your reply, I checked and everything seems to be fine concerning the ribbon cable.
In fact, the FS6 switch is blocked all the time, the others worked fine right after the reflashing when I did it for the first time.
There must be a problem with the FS6 switch, my warranty is over anyway so maybe I should bring it to the shop I got it from and ask for help.
Thanks anyway guys !
Finalchimera
#7 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
Posted 08 October 2013 - 07:07 AM
Did you try some electronics contact cleaner into the switches? Unplug it obviously. Buy a can of the aerosol contact cleaner and spray all the foot switches one at a time and press them several times to work the cleaner in and try and clean out any gunk. Worth a try!
#8 Finalchimera
Finalchimera
  • 11 posts
Posted 08 October 2013 - 11:49 AM
Hey Stumblinman !
I'll do that asap, I'll get back to you to let you know if it worked ;o))))
Finalchimera
#9 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
Posted 17 October 2013 - 10:38 AM
Hey Stumblinman !
Finalchimera
Just checking up on this. Any luck? Curious what you discovered.
#10 edilsonaragaojr
edilsonaragaojr
  • 1 posts
Posted 01 December 2013 - 12:36 PM
I have the same problem...Would you help-me?
#11 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 02 December 2013 - 03:05 AM
Also tagged with one or more of these keywords: footswitches
