shredster34 Posted November 5, 2017 Share Posted November 5, 2017 I need help programming my ART X11 midi board with my POD 2.0 Is there an easy way of doing this? At the moment it just runs through the patches 1 a b c d then 2 abcd etc...But Id like to be able to set up patches myselfIts an older pod 2 so the floorboards dont exist anymore Can any one help? Do I need to program the pod or do it from the X11? Thanks guys any help would be appreciated Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 6, 2017 Share Posted November 6, 2017 Its been a long time since I looked at the X-11 but I used a X-15 (should be similar) there is a pedal board mode that you can use it should be in the manual. Use it for setting the Pod's ccs for the fx you are looking to trigger. For the X-15 I used this: http://www.x15setup.com/english.htm Which was a lot easier. You can still find the older floorboards used the usually run ~ $50 - $75. If your Pod 2.0 reads FBV above the port you can use the FBV. If it read "pedal" then yes, you have to find the older floorboard - they are pretty nice with the dual exp pedals. Quote Link to comment Share on other sites More sharing options...
