Program ART X11 for Pod 2.0
I need help programming my ART X11 midi board with my POD 2.0
Is there an easy way of doing this?
At the moment it just runs through the patches 1  a b c d then 2 abcd etc...
But Id like to be able to set up patches myself
Its an older pod 2 so the floorboards dont exist anymore
Can any one help?
Do I need to program the pod or do it from the X11?
Thanks guys any help would be appreciated
Its been a long time since I looked at the X-11 but I used a X-15 (should be similar) there is a pedal board mode that you can use it should be in the manual. Use it for setting the Pod's ccs for the fx you are looking to trigger.
For the X-15 I used this: http://www.x15setup.com/english.htm
Which was a lot easier. You can still find the older floorboards used the usually run ~ $50 - $75. If your Pod 2.0 reads FBV above the port you can use the FBV. If it read "pedal" then yes, you have to find the older floorboard - they are pretty nice with the dual exp pedals.
