pfeathers Posted October 6, 2013 Share Posted October 6, 2013 I've just purchased 2 L3t's for connection to my HD 500 Pro. The decision for purchasing the L3t's was simply the versatility of the speakers & the L6 link. I play in live bands as well as in duo's so the idea is the L3t's are simply used as a stereo setup in a live band situation with patches changing between electric & acoustic guitar speaker modes on the L3t's, so far so good. When the L6 links are connected from the HD 500 pro the L3t's read 1 & 2 & if I switch off the HD 500 Pro, they then revert back to L & R, I'm assuming this is correct. However when the L6 link is used & a music source for backing tracks is connected into the audio connections no signal from the backing tracks is being sent to the speaker numbered 2. I then tried connecting the HD 500 from the L & R XLR out puts into separate channels on each speaker with the L6 link only connected from 1 speaker to the other. This then solved the problem of the music source signal being sent to just 1 speaker. I guess my question is, is there a way to connect the HD 500 Pro using the L6 Link to the 1st speaker then the L6 Link to the second speaker & have the music backing track source signal sent to both speakers ? My feeling is that in a duo situation I'd be using the setup in PA mode & therefore will not be able to benefit from the L6 link capabilities for the HD500, I hope this all makes sense. Any help & suggestion would be much appreciated. Quote Link to comment Share on other sites More sharing options...
jbstudtm Posted July 22, 2014 Share Posted July 22, 2014 Was your issue ever solved? No one ever answered u. I have been trying to work out this same thing with my pod hd PROX and 2 l3ts. Have submitted ticket and no answer yet from line 6. Pretty frustrated that I have 3 grand in gear that isn't working as advertised with l6 link. Quote Link to comment Share on other sites More sharing options...
pfeathers Posted June 8, 2015 Author Share Posted June 8, 2015 Unfortunately no response :( Quote Link to comment Share on other sites More sharing options...
