Tonepoert Ux2 And Monitoring
7 replies to this topic
#1 nicethugbert
nicethugbert
  • 4 posts
  • Registered Products:1
Posted 07 October 2013 - 02:27 PM
I have a Tonepoert UX2 and I do not want ot monitor through it.  I've looked in Gearbox's settings and have not found a way to stop my Tonepoert UX2 from being my monitor source.
The reason I do not want to monitor through Tonepoert UX2 is because it has no EQ for anything but the instrument.  Yet, when Gearbox is open and Tonepoert UX2 is connected to my PC, all audio is routed through Tonepoert UX2.  My instrument sounds fine.  But, without EQ, everything else sounds bad.  This may not be a problem when I'm recording because the recording software can have EQ.  But, when I am practicing or playing computer games or listening to WMP, those sources sound bad.  Normally, I listen to audio on my PC through my Logitech G900, which has EQ that I use so audio sounds good.
So, how can I use Gearbox and Tonepoert UX2 and monitor through my PC with my Logitech G900 headphones?
#2 nicethugbert
nicethugbert
  • 4 posts
Posted 09 October 2013 - 01:44 PM
Hello, anybody here?
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 09 October 2013 - 01:59 PM
ASIO requires the same hardware for input and output.
what you want to do is outside of that specification, and only a hack or some sort of workaround will accomplish...
and it will do so by sacrificing accurate latency and possible introducing digital artifacts....
not worth it.
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7365 posts
  • Registered Products:6
Posted 11 October 2013 - 05:49 AM
I would recommend investing in a mixer. I small one should suffice.
#5 k_zurawski
k_zurawski
  • 25 posts
Posted 05 November 2013 - 10:53 PM
How a mixer will solve the problem?
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7365 posts
Posted 06 November 2013 - 06:41 AM
Because you can have multiple sources routed to your mixer. In your case you pc's sound card and the UX2. Then the main outs of the mixer to your monitors and/or headphones.
#7 k_zurawski
k_zurawski
  • 25 posts
Posted 07 November 2013 - 01:06 AM
But you still have to change through which device system sounds are being send and through which device you may record.
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7365 posts
Posted 08 November 2013 - 06:53 AM
That is correct.
I know some users have routed the analog outs of the UX to the PC's Line In, but that is somewhat of a convoluted hook-up, but it may be what you're after.
If that works out you should still use the UX as an ASIO device into your DAW for recording though.
