POD studio UX2 with Pod Farm 2.5 - Can't detect guitar
help ux2 pod farm pod studio guitar pc
10 replies to this topic
#1 dmott92
dmott92
  • 10 posts
  • Registered Products:1
Posted 26 December 2017 - 04:51 PM
So I know that similiar problems have been posted here in recently, but none of the fixes work for me. I recently got the POD studio UX2, and installed POD farm 2.5 on my PC, along with all the necessary drivers (line6 monkey and the hardware driver) and registration steps. Unfortunately, I am still not able to get the interface/software to pick up my guitar. I have both my recording and playback devices set to the interface, selected "instrument" on the POD farm input menu, have the UX2 selected in the hardware preferences tab, and my guitar/cable works through an amp. The interface is lit up (yellow/orange lights on), but the dials don't move at all. I also noticed that I am unable to hear any other sounds from my computer (youtube/Spotify), so I am not sure if this helps isolate the issue.
At this point I have no idea what to do and am considering opening up a ticket. Does anyone have any advice? Thanks
#2 Gaz_Ham
Gaz_Ham
    Iknowathingortwo
  • PipPip
  • 116 posts
  • Registered Products:2
Posted 27 December 2017 - 02:27 AM
Are your speakers plugged into the ux2 or your pc? What operating system do you use?
#3 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
  • LocationNew England
  • Registered Products:3
Posted 27 December 2017 - 05:16 AM
Are you running Windows?  Make sure that the UX2 is selected as the audio device in its Sound tab, and that the audio volume control is not at 0%
#4 dmott92
dmott92
  • 10 posts
Posted 27 December 2017 - 08:26 AM
I am running Windows 10, and I was trying to play the sound through my computer by playing around with "listen to this device" under the recording device management window. Should I try plugging in headphones into the interface?
#5 Gaz_Ham
Gaz_Ham
    Iknowathingortwo
  • PipPip
  • 116 posts
Posted 27 December 2017 - 11:17 AM
My speakers and headphones are connected to my ux2 and the playback settings are set to ux device for playback.
The listen back to device setting is the same as monitoring your track inside a DAW. Both causes slight latency for me, so it's pretty much an un-useable function on my set up, other than for fine tuning. Try using your interface for all possible ins and outs
#6 dmott92
dmott92
  • 10 posts
Posted 27 December 2017 - 01:22 PM
I will try this, first I have to find my headphone converter... Pretty sure my cat got a hold of it.
#7 dmott92
dmott92
  • 10 posts
Posted 27 December 2017 - 01:30 PM
Also, unrelated to my issue, but you think if I had the output set to play though my computer, and had my computer connected to speakers, that would create too much of a delay? I have a nice Bluetooth speaker system set up do it would be awesome if I could do this
#8 dmott92
dmott92
  • 10 posts
Posted 27 December 2017 - 04:38 PM
UPDATE: ​For some reason I am getting "audio" now, although its really just a buzzing static. It only occurs with the guitar plugged in and when I strum it.
Here's a link:
#9 Gaz_Ham
Gaz_Ham
    Iknowathingortwo
  • PipPip
  • 116 posts
Posted 28 December 2017 - 12:47 AM
I've never tried to out put through my pc. It's worth giving it a go.
Some have had trouble with Windows 10,some have got it working, Some haven't. Try different usb ports and reinstall the latest drivers, via monkey or line6.com. Search this forum for Windows 10 problems, Some may help. You can always try speaking to line6 directly, via a support ticket
#10 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2576 posts
Posted 28 December 2017 - 05:13 AM
If you use the UX2 for monitoring (headphones/speakers), latency should be at the minimum.  Using the internal soundcard on your computer may create longer latency times.  Bluetooth could, as well.
#11 dmott92
dmott92
  • 10 posts
Posted 01 January 2018 - 07:21 PM
So I put in a ticket a few days ago. No response yet. Did you guys check out the video I posted?
Also tagged with one or more of these keywords: help, ux2, pod farm, pod studio, guitar, pc
