Serious Bug In Workbench And Jtv
Best Answer guilhordas , 08 October 2013 - 12:53 PM
I want to thank the attention of all, I did find out, as Phil had said, The cable I use should probably be broken inside, but to connect to jtv in pod it works but does not work for the workbench. I was just picking up another ethernet cable and connect and worked, the problem was actually the cable. Thanks
Go to the full post
  • This topic is locked This topic is locked
60 replies to this topic
#1 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
  • Registered Products:2
Posted 08 October 2013 - 05:14 AM
I decided to open a topic because the problem of my workbench and my jtv appear serious
.I often have received this message when I try to make a WB Operating,  "failed to write data to the guitar" and the sound of that model I'm changing mutes ., and now I can not get sound to come back in all positions of TELE or strat, the workbench repeats this error message
Now, Several models are dumb and a strange writing on the workbench
I tried to reinstall the firmware 2.0 but also get the error message, (error midi opening ports)  I'm having serious problems, ,
The names of the models were all changed and are now all are with strange letters
after many attempts I managed to reinstall 2.0 and returned my previous bundle, but still keeps giving bug, reinstalled the workbench but also not fixed.
switched from pc to notebook and my wife also not resolved.
In the workbench, question marks appear over the pickpus
anyone imagine what might be happening?
I have attached some pictures.
Thanks
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
  • LocationMinneapolis, MN
Posted 08 October 2013 - 05:33 AM
It could be a bad VDI cable... Are you using the cable that came with the Workbench interface or are you using the longer VDI cable?
#3 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 05:41 AM
I'm using a 4 meter cable, the picture of the cable is at this link, if you can look thanks
http://produto.merca...-c-3-metros-_JM
#4 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 06:02 AM
strange is that our communications between pod hd and jtv is perfect, the problem is when I connect with pc
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 08 October 2013 - 06:05 AM
That cable does not have the protective housing at the ends that a VDI cable provides. Regular use of an unprotected cable like this usually results in damage to the connections on the Variax and/or the HD500.
Here is the VDI cable. Note the protective housing on the cable ends:
https://www.globalfu...ode=98-030-0004
It is very possible, if not likely, that you have damaged your ports.
.... John Lennon
#6 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 06:16 AM
i have this original cable but it is also very thick and heavy, so I do not use.
the cable that I use I've attached a photo for you to see.
a question, if my cable not suitable it should not work, right? but as said before, communication jtv with the pod is perfect, the problem happens only in the workbench
#7 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 06:39 AM
you do not think the problem may be with usb interface or usb cable?
#8 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 06:52 AM
The problem could be the interface or the USB cable, but I'd be more suspicious of the Cat5 cable... This is just me speculating, but I believe the data being sent from the Workbench interface when updating and using Workbench is essentially MIDI sysex data, or something very much like it. When you're using the Variax with a POD, the data is more like MIDI PC and CC commands. Sysex data is more like a data stream and the MIDI commands are more like bursts of data being repeated. Sending commands is more forgiving than sending sysex. So I think it's likely that a bad cable could show up when using Workbench and not with the POD.
#9 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 08 October 2013 - 06:56 AM
Yes - it may be a usb problem. It may also be your CAT5 cable. Since you have the original cable (at least protected on one end) why not test it? But remember - if this does not work that doesn't mean that it is a usb problem - it may be (and likely is) damage to the VDI connections/ports within one of the devices.
Long term you should definitely be usinga VDI cable protected at both ends.
.... John Lennon
#10 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 06:59 AM
Well, at least at the Variax end... The cable that comes with the JTV is only protected at one end.
#11 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
I have 2 cables vdi here and 2 are giving the same problem, now jtv is no sound, only one or another model is sounding, I'm very upset because I have a gig tomorrow and my guitar is muted. what is your suggestion Phill?
#12 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 07:02 AM
Have you tried reinstalling the firmware using the HD500 instead of the Workbench interface?
#13 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 08 October 2013 - 07:03 AM
Right - sorry for any confusion. I was talking about using the Variax with a compatible Pod device.
.... John Lennon
#14 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 07:05 AM
the original cable that came in the jtv I have no more, but I bought this one
http://www.ebay.com/...=item4d1298adbc from the link, which is also original. the 2 cables give the same problem
I'm going crazy here, also already tested two usb cables, the only thing I do not have two is the usb interface.
#15 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 07:06 AM
but it is possible to install the 2.0 with the pod?
#16 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 07:08 AM
yes, but how will I connect the USB interface if the two sides are protected?
#17 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 07:09 AM
Yes, it is... I actually would recommend using that people POD to do the update as standard operating procedure if they own one. It seems like a more robust connection to me. The only thing you can't use the POD for yet is connecting to Workbench HD.
#18 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 07:18 AM
Should I reinstall the models button on or off?
#19 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 07:22 AM
I honestly don't think it matters that much when you do the update with a POD. You do need to make sure the volume knob is turned up. But as long as Monkey recognizes the guitar, you should be fine. I probably had the models turned on when I did mine. To be honest, I didn't pay attention to it when I updated. I just did what the Monkey told me to do.
#20 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
I am trying to install in a pod but I got this error message attached below
#21 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 07:32 AM
I succeeded in reinstalling the 2.0 trough the pod, sounds again, now I need to install my bundle, this is the problem
#22 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 09:03 AM
I succeeded in reinstalling the 2.0 trough the pod, sounds again , but when I open the workbench gives the same problems, strange letters, models muted, what you think I should do phil?
#23 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 10:30 AM
Is Workbench doing this after you load your existing bundle? If so, I'd say the presets in that bundle may be corrupted. It is probably best to start from a clean slate and not try reloading those patches.
#24 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1833 posts
  • LocationGreece
  • Registered Products:12
Posted 08 October 2013 - 11:39 AM
Through the pod???? I though to use the workbench HD it's possible only with the small Hub...
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#25 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 08 October 2013 - 11:49 AM
The only way to use Workbench HD at the present time is to use the Workbench interface. To do the update, though, you can use any device with a VDI interface.
#26 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 12:53 PM   Best Answer
  • 1
#27 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 08 October 2013 - 12:55 PM
yes, I didnt know it was not possible to install the 2.0 connected through the pod, I thought it was only possible by USB interface, but Phill warned me that it was possible
  • 1
#28 jegler
jegler
    Iknowathingortwo
  • PipPip
  • 134 posts
  • LocationThe Basement
  • Registered Products:6
Posted 08 October 2013 - 01:12 PM
With v2.0 i got the same error mssg as guilhordas, but I reinstalled and that went ok, but now my high E and B string are like half the volume of my other strings - across all models. But wait - I have most of my patches saved with the JTV model and the tone set from 50-70% (all models just sounded harsh to me at 100%). If I set the tone to 100%, the string volume discrepancy goes away, but now I'm back to harshville and when I roll the tone back down, no top strings. Arrgg! This was NOT the case w/v1.9. I played a number of gigs before the "update" and everything sounded fine. I tried re-installing 2.0 but no help. Does anyone know if rolling back to v1.9 will fix this? I'm afraid of the Line6 Monkey now.
www.redlightrecords.com
#29 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1833 posts
  • LocationGreece
Posted 08 October 2013 - 08:41 PM
It is normal for the version 2.0, you can do manually the correction...Otherwise yes, by reverting to 1.9 will solve the problem automatic.
#30 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 09 October 2013 - 05:48 AM
I don't know that I agree that it's normal... I've not altered the volume of the strings on my JTV69 since doing the update, and it sounds fine to me. I don't know why some people seem to have this issue and others don't. I suspect there could be differences in the levels of piezo between the models.
But, yes, altering the volume of the strings is easy to do in Workbench.
#31 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 09 October 2013 - 10:09 AM
Today something strange happened, I went to fix the cable that was giving trouble in the workbench, but it worked in the pod, and to my surprise the cable is not defective, I used a device that measures 8 wiring cable and all were working, then I wonder why this cable does not work correctly with the uSB interface and workbench? and the strange thing is that standard cable network from my interenet works
#32 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 09 October 2013 - 10:52 AM
Some Ethernet cables are called 'crossover' cables. These do not work with the Line 6 products. You may have one of these; if so you need to use a standard (non-crossover) cable.
.... John Lennon
#33 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 09 October 2013 - 11:31 AM
Just FYI if anyone cares... a crossover cable simply has the transmit and receive pairs swapped (orange and green) in the network context....
far more dangerous in the "use for anything other than network" context... as certain pairs will carry the power....
(as determined by engineering/manufacturer)
so under no circumstances should a crossover cable be used in a non-networking context unless you know the pinouts (not public to my knowledge) and assume the risk.
#34 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 09 October 2013 - 12:48 PM
The cable that i use with my jtv and pod is this http://produto.merca...-c-3-metros-_JM , this cable works perfectly to use with pod but doesnt work to workbench
#35 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 October 2013 - 07:39 AM
the problem happened again, I'm going crazy, I already changed the pc, swapped cables, reinstalled the firmware, but I'm having the same problems again
#36 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9229 posts
Posted 15 October 2013 - 07:49 AM
Sounds like the only thing you haven't changed is the interface. It could be the port on the interface is damaged. Or it could be the port on the guitar itself.
#37 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 15 October 2013 - 08:11 AM
This really sounds like the USB port cannot supply enough current to run the interface reliably.  I know that the Line6 documentation says not to use a USB hub, but a powered USB hub (with wall wart) can likely supply more current than the computer.  If you have one or can borrow one, it may be worth a try.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#38 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 October 2013 - 08:33 AM
the line 6 might think the problem may be with the usb interface or with my jtv, but the interface seems to work well, turn lights properly, the workbench always recognize the JTV through it,
can you post a links of this product? thanks
#39 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 15 October 2013 - 08:50 AM
Well, obviously it is not working correctly if your attempts to stream data to the instrument are terminating with errors.  Small voltage drops that are enough to cause digital circuit misbehavior might not be obvious from watching LEDs.  You would have to put a scope on the +5V line at the interface to have a chance at seeing it directly.
There are hundreds of powered USB hubs available.  Google is your friend ("powered usb hub" might be a reasonable search term).  Anything with an external supply and USB 2.0 compatibility is a good bet.  But please keep in mind that I am only throwing that idea out because I've had similar problems when, e.g. copying files to my Tascam guitar trainer.  The unit is always recognized and mounted by my computer, but if plugged into a rear-panel USB port it disconnects part way through any file transfer.  If I connect to my little powered hub, it works perfectly.  Other things to do (if you haven't already):
- Swap USB cable
- Check computer and Line6 interface box for bent or visibly tarnished pins (strong light and magnifying glass are helpful)
- Try a quick shot of non-residue electronics cleaner in the computer and interface box, then work cable in and out about a dozen times.  Do NOT use anything with lubricant in it (aka "tuner cleaner") or you'll definitely regret it.
- Check your computer setup for the presence of any non-Line6 device driver that may be trying to listen to the USB ports.
(My money is on the current capacity issue)
#40 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 15 October 2013 - 09:50 AM
thanks man iII try
