Serious Bug In Workbench And Jtv
Best Answer guilhordas , 08 October 2013 - 12:53 PM
I want to thank the attention of all, I did find out, as Phil had said, The cable I use should probably be broken inside, but to connect to jtv in pod it works but does not work for the workbench. I was just picking up another ethernet cable and connect and worked, the problem was actually the cable. Thanks
Go to the full post
  • This topic is locked This topic is locked
60 replies to this topic
#41 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
  • Registered Products:2
Posted 15 October 2013 - 10:07 AM
THE ONLY THING NOT TRIED YET, BECAUSE I DO NOT OWN, IS ANOTHER USB INTERFACE, I ALREADY CHANGED CABLES COMPUTER. A WEEK AGO I USED MY ETHERNET CABLE INTERNET AND WORKED PERFECTLY, SO I concluded that SHOULD BE TROUBLE CABLE, BUT TODAY WAS TESTED WITH CABLE AND EVEN HAD THE SAME OLD PROBLEMS
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#42 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 16 October 2013 - 08:22 AM
I changed the usb cable and ethernet cable for new and nothing, the problem remains, the strange thing is that I do not have any problem to reinstall 2.0 through the pod, I just have a problem when I use the workbench through the usb interface
#43 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 16 October 2013 - 02:05 PM
So you've tried the powered hub and that didn't help?
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#44 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 16 October 2013 - 02:25 PM
not yet tried, missing just try it, found not to buy today, but I'll keep looking
#45 Krom_
Krom_
  • 7 posts
Posted 25 November 2013 - 12:05 AM
I have the same problem and line6 support seems to have no idea about this issue. Too bad because I really can't be sure if I have to return USB interface only or the guitar too. And it is really a problem, since the dealer is located 2000km away (how about $200 for a return shipping?)!
Why do I think it is interface or guitar problem? I tried:
1. Swapping USB cables
2. Swapping Cat5 cables
3. Swapping PC (another OS version, another usb port)
4. Using powered USB hub (bad idea, snhirsch, really - it made strings and cable jack energized)
5. Reflashing many times
6. Using POD HD500 as an USB interface
And after 5 and 6 I still have questions. There were a couple of times when I've managed to upload changes to the guitar (fw 1.9) via USB interface, but most of the time it failed. There was an error while I was trying to upload a change for the first time via HD500, but then it worked. I actually not quite sure about how well does it work with a HD500 compared to an USB interface, because my testing with the HD500 was rather brief (in a store), and it still worked some times with the supplied USB interface. Anyway no testing I was able to make with another USB interface and fw 2.0, that leaves me in doubt about actual problem cause.
#46 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 25 November 2013 - 03:37 AM
I'm having so many problems that I decided to no longer use the 2.0 workbench until the line 6 correct any bugs and allow us to use through the pod hd
#47 Krom_
Krom_
  • 7 posts
Posted 07 December 2013 - 01:30 PM
I have solved the problem. It was faulty usb interface.
#48 Rlivingst
Rlivingst
  • 2 posts
  • Registered Products:1
Posted 13 December 2013 - 01:34 PM
I've seen a lot of the same issues you have. Tried to update multiple times and kept getting that same connection error. It finally worked, but now my presents change randomly. I can't rollback to a different version either because of the connection errors. I'm going to have to send the thing back to Line6 and I just got it yesterday. Should I even keep this guitar? It kind of seems like more trouble than it's worth.
#49 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 14 December 2013 - 10:17 AM
many people are having serious problems, but the experts say that this is not bug, so I'm not understanding anything
#50 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 14 December 2013 - 10:39 AM
its just a matter of what you are calling it...
it *IS* a seriously annoying limitation...
so really we're not disagreeing with your sentiment... we are only clarifying the nature of your complaint.
#51 Krom_
Krom_
  • 7 posts
Posted 15 December 2013 - 01:12 PM
It's ridiculous to call hardware defect in a lot of usb interfaces a limitation. Especially for an "expert".
Again: I've got mine replaced and it works well now.
#52 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 December 2013 - 01:15 PM
Yeah that would have been ridiculous... if that's even remotely what i said...
i said the inability to use a pod as a means of accessing workbench was the limitation...
nothing to do with broken interfaces...
okay cowboy... ease up.
#53 Krom_
Krom_
  • 7 posts
Posted 15 December 2013 - 01:25 PM
This limitation has exposed a show stopper defect. That's why the situation in overall is not just a limitation. (but I'm sorry for being too harsh)
#54 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 December 2013 - 01:48 PM
you're drawing a whole lot of conclusion from your own personal experience...
myself and many others have perfectly working interfaces...
sorry that obviously wasn't the case for you...
not much showstopper IMO, since i could update with the pod and never touch workbench, and still been very happy with the quality of v2.0
if you have no pod and only a broken interface... then yes it was a showstopper.
but i'd not say that affected the majority of users.
#55 Krom_
Krom_
  • 7 posts
Posted 15 December 2013 - 02:17 PM
Those broken interfaces do an update. But after update you can't edit a patch neither via interface (broken) nor via pod (here comes that 2.0 limitation). And an existence of this, maybe not widespread, problem must be admitted.
#56 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 15 December 2013 - 02:49 PM
Perhaps I've missed something but as I understand it, Krom_, you had a fautly usb interface - a hardware problem that you said you have resolved. That certainly was a problem for you, though it's not widespread as far as I know. I'm not sure that's a problem that 'must be admitted'.
Is there another problem you are having now that points to something serious?
.... John Lennon
#57 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 December 2013 - 03:48 PM
the broken interface apparently does not correctly apply the update... because if it did workbench HD would work through the interface.
the other limitation has already been admitted....
and you could have applied the update via pod... just not use workbench.
anyway....  no sense in arguing... the pod limitation will eventually be addressed and your interface has already been addressed from the sounds of it.
#58 Krom_
Krom_
  • 7 posts
Posted 15 December 2013 - 10:27 PM
I really can't understand what are you arguing about.
There are several posts about problems caused by usb interfaces. This cause is not obvious: it might be a guitar electronics or a software problem (and this tread is an example of such confusion).
I solved mine and I'm sure that there must be clear conlusion: if one have problems after switching to 2.0 (and so, being unable to use a pod instead of an interface), it is likely an interface problem.
People coming to the forum with a problem are not for reading coneptual chats about limitations, but for a help.
#59 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 16 December 2013 - 04:35 AM
ok... but the basis of the thread is not about the usb interfaces... and a bad interface is not a bug... its a bad interface.
you're the one arguing...
i'm giving you facts.
#60 Krom_
Krom_
  • 7 posts
Posted 16 December 2013 - 04:43 AM
The basis of the thread is about the problem, caused by the usb interface - of course it isn't a workbench bug. And *this* is the main fact and the conclusion of the thread :)
#61 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 16 December 2013 - 05:20 AM
This thread was resolved and marked answered long ago.
if you have a bad interface contact support.
http://line6.com/support/tickets/
  • -1
