Line 6 Pod Pro Hd Not Loud Enough?
pod pro hd loud volume
7 replies to this topic
#1 ZomgAnthony
ZomgAnthony
  • 4 posts
  • Registered Products:1
Posted 08 October 2013 - 06:58 AM
Hi guys, I recently bought a Pod Hd Pro rack off of a friend and I'm running this through a ART SLA-1 Power amp (100watts@8ohms) and into an Avatar 8ohm cab (120 watts) with celestian V30s. I was practicing with some guys the other day, and for some reason, I have to crank the master AND channel volume all the way to the max to even hear it at a decent volume compared to everyone else(Drummer+6505 guitarist). Are there any settings I should be changing on the pod pro so that it is used for live amp use? or perhaps maybe the power amp is just not that strong?..
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9060 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 08 October 2013 - 07:01 AM
You want to make sure you have the switch on the back of the unit for the XLR outs set to "line" and not "mic".
#3 ZomgAnthony
ZomgAnthony
  • 4 posts
Posted 08 October 2013 - 07:17 AM
I just went to my car and check on it, and it's already on the Line setting instead of mic. the other switch is also on ground right now. I'm just a complete noob when it comes to hooking these things up. and also.. If I decide to hook the pod pro to my power amp using a speaker cable, the unbalanced output is set to Amp and not Line. I can't think of anything else right now besides maybe a setting to change on it or something.
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9060 posts
Posted 08 October 2013 - 07:41 AM
That should be set to "line" also. You'd set it to "amp" if you were plugging into the front of a guitar amp or going into some other device expecting an instrument level signal.
#5 ZomgAnthony
ZomgAnthony
  • 4 posts
Posted 08 October 2013 - 07:43 AM
Hmm.. I'll try that next time I'm around my cab! Thanks
#6 yxyxyxy
yxyxyxy
  • 18 posts
  • Registered Products:6
Posted 19 October 2013 - 08:21 AM
First of all you have the Wrong Amp. ART SLA-1 has no 1/4" output jack, that makes me assume that you are using Bare speaker wire instead of "Speaker Cable". I don't know how your connecting amp to the speaker cab, but if your using household speaker wire, then that's what your doing wrong. I use a Carvin DCM200L and its loud..dcm200l-closeup-2.jpg And it has the output's for the speaker cabinet.dcm200l-closeup-3.jpg
#7 ZomgAnthony
ZomgAnthony
  • 4 posts
Posted 19 October 2013 - 09:37 PM
I use a banana plug to connect into the multi post binding outputs in the back(red and black). and that banana plug allows me to use a 1/4 speaker cable to connect into my cab. I found out that the issue I was having was that I was still on the Direct/recording setting when it should have been something else. It sounds a lot louder, and more hear-able at practice. so my issue was pretty much solved
#8 yxyxyxy
yxyxyxy
  • 18 posts
Posted 20 October 2013 - 10:46 AM
Great, and hears a tip. Your using one cab so you have a Mono setup,  I too had issues with volumes and my setup was stereo out to stereo in of my power amp and stereo out into stereo 8 ohms L and 8 ohms R  of my cab. For some reason it didn't work right, I had low sound, tone was a bit off and it sounding like I was hearing it from far away. After many weeks of seeking Forum knowledge, nothing.
  So here's what I did Rewired everything into Mono mode,  channel 1 output of the pod is mono ,so connected here to channel 1 input of the stereo power amp which I bridge to mono and used the  channel 1 amp output (16 ohms)  into 16ohm input of my cab. Sorry about going into detail, but wait  there's more.
 On the Pod in the mixer block, I had to Pan everything Hard LEFT 100% into the Pods output channel and that's what worked for me.
 next time when your playing try Panning 100% to your output and see what it gets you.
Also tagged with one or more of these keywords: pod, pro, hd, loud, volume
