Fs Controllers And What They Control
5 replies to this topic
#1 joeloduca
joeloduca
  • 10 posts
  • Registered Products:1
Posted 07 May 2013 - 01:57 AM
Hello all,
Got a HD 500 and I like to occasionally set up some of those FS buttons to turn on or off certain effects.   So I kind of know how to assign those FS buttons..  (I also use LINE 6 POD HD500 edit on my PC).   The problem I am having is some of the FS buttons are set to "MULTI" while its toggeling multiple effects on and off..  I don't want this, I only want the FS to control ONE effect.  I can't seem to figure out how to get this off of MULTI..   Anyone know?
joe
#2 SiCantwell
SiCantwell
  • 74 posts
Posted 07 May 2013 - 04:05 AM
Go to the Controllers tab and see which footswitch each effect is linked to. Multi means more than one effect is linked to a certain FS, so delink or reassign any effects you don't want linked to that FS.
#3 joeloduca
joeloduca
  • 10 posts
Posted 07 May 2013 - 04:20 AM
Thanks, but that is exactly what i am trying to find and cant.. I don't understand how to delink that controller to only control 1 effect. I've tried various things on the PC as well as the HD and I cant seem to get rid of the MULTI ..
#4 scheater5
scheater5
  • 79 posts
Posted 07 May 2013 - 05:51 AM
Should be pretty simple from HD Edit - "hurghanico" has it right.  To put it another way - realize that "multi" means several effects are linked to one switch.  Go to the "FX" window in HD Edit, and press the switch a few times.  See which effects are toggling on and off.  Then go to "Controllers" and chose the effects you DON'T want controlled from the first drop down menu - under "FS Assign" change it to "none."  Leave the one that you DO want that switch to control alone.  Now instead of "Multi" it should just say the one effect you want.
#5 scheater5
scheater5
  • 79 posts
Posted 07 May 2013 - 06:28 AM
HA!!  Wow, shows you how much I've used the new forum.  Opps.
*above post has been corrected*
#6 joeloduca
joeloduca
  • 10 posts
Posted 07 May 2013 - 04:33 PM
Hey Guys, I want to thank you all for the solutions..   I finally got this thing working the way I want..
Special thanks to "Iknowathingortwo"..  you really do know a thing or 2...
thanks and have a great day!   Joe
