Acustic Sounds : Jtv Vs Variax300
18 replies to this topic
#1 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
  • Registered Products:2
Posted 07 May 2013 - 03:27 AM
Yesterday for the first time I could compare my jtv 69 with a Variax 300, in a same pod hd500 and same parameters, and my impressions were: the electric sounds of jtv are really superior, more realistic, but the acoustic sounds of the Variax 300 sounded much better in my humble opinion, I thought the guitars of 300 acoustic softer, less aggressive, more softly, more balanced. I thought the 300 best in the 5 positions of acoustic sounds
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
  • LocationClemmons, NC USA
  • Registered Products:16
Posted 07 May 2013 - 04:27 AM
the JTV firmware has the latest "HD" acoustic models... if you want the same acoustic models as the earlier variax you would need to roll back to firmware 1.7x
you'll of course lose features and support...
but all the electric models are due to get the same "HD" makeover soon.
#3 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 05:25 AM
but if I roll back to 1.71 firmware will I have exactly the same sounds of the Variax 300?
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 07 May 2013 - 05:35 AM
as near as possible... still the physical guitar to factor in... but yeah the models would be the same... you'd of course be able to alt tune them on the fly unlike the 300
#5 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 06:03 AM
ok thanks ZEP, but if I do rollback what happened with the electric models,? any change drastically?
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 07 May 2013 - 06:07 AM
the electric models are already the same... the update to the electric models has not been released.
you will of course lose some functionality and fixes... but for the most part it will be equivalent to the 300 so if that was good enough then you're golden.
*some of that functionality is the ability to use the variax as a expression/controller.
and an example of a "fix" would be the improved pam muting would be gone back to variax 1st gen levels.
#7 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 06:58 AM
Zap last question, can I do the roll back and if I do not like it, go back to the current firmware without losing anything?
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 07 May 2013 - 07:01 AM
you can downgrade and upgrade without any issues.
#9 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 07:07 AM
but the different piezzos and body  between 300 and JTV also influence the sound, correct?
#10 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 07 May 2013 - 08:28 AM
the physical instrument of course affects the sound... but very mildly when you are playing the same basic underlying model....
heck if they both sounded 100% identical... the feel would affect my playing and create slight differences...
it's no harm to try it, i personally would just get used to the new acoustics :) i mean i wouldn't want to miss out on whatever comes next.
#11 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 08:36 AM
Thank you very much
#12 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 07 May 2013 - 08:28 PM
I really think the line 6 could make a good improvement in the sounds of acoustic guitar, just the jumbo is actually usable
#13 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 08 May 2013 - 03:12 AM
they aren't likely to change them again... just released them in 1.8x and tweaked them a little after that.
who knows though... the new version of workbench coming with update 2.0 may allow us to make adjustments...
#14 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1961 posts
  • Registered Products:3
Posted 08 May 2013 - 11:34 AM
This. I believe any difference is sound is due to the different piezo pickups between the JTVs and V1 Variaxes.
For a minute there, I lost myself.
#15 Leftzilla
Leftzilla
    Gear Head
  • PipPipPip
  • 520 posts
  • LocationBurlington, VT
  • Registered Products:10
Posted 09 May 2013 - 08:19 AM
There have been some complaints about the new JTV HD acoustics since they add some room ambience to the actual emulation.  Since this cannot be removed some users preferred the previous sounds.  Also don't forget to play with your tone knob as this will control the compression and (I think) the microphone position relative to the sound hole.  (Simulated)
#16 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 11 May 2013 - 07:07 PM
I think the line 6 could give us the chance to choose which firmware to use, but without losing the improvements of the new updates
#17 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17705 posts
Posted 11 May 2013 - 07:39 PM
will never happen...
you can run the older or the newer your choice, but they aren't going to offer custom firmwares.
#18 brettwade
brettwade
  • 19 posts
Posted 02 September 2016 - 08:31 AM
This is the comment I've been looking for! I have a new JT89f and my old frankenstein 300 has more usable acoustic sounds. I can't get rid of the "room" sound. It's ridiculous to have added that into a model. It leaves a person stuck with a room verb on every model. I thought I had the only variax with that problem  because all the sounds on Youtube sound great but I notice they're all from older JT versions than mine. Where did you get the info on the added room sound? Thanks for the comment by the way.
#19 Leftzilla
Leftzilla
    Gear Head
  • PipPipPip
  • 520 posts
Posted 02 September 2016 - 08:44 AM
Brentwade, this statement I made was in reference to what others had posted in this topic. I personally prefer the new jtv acoustics, but others do not.
