sgrain Posted January 18, 2018 Share Posted January 18, 2018 I there Forum , see if you can help me. So , i record a loop , than i press the volume pedal to mute the sound and record another loop , why when i press the volume pedal up the last loop doesn´t apear ! beste regards Quote Link to comment Share on other sites More sharing options...
sgrain Posted January 19, 2018 Author Share Posted January 19, 2018 in case you stop the Looper playback, and later you want to hear again what previously recorded in order to add some overdubs to it, first you should press the PLAY button and only after the RECORD/OVERDUB button.. if you press the RECORD/OVERDUB button while the Looper playback is stopped, everything previously recorded is erased.. also, as soon as you eventually engage the tuner, any Looper recording is erased Sorry about my terrible inglish , i will try to explain my problem again. supose that you want to play 2 loops when you are preforming live. how do you record the loops without the plublic or audience listen ? or only listem the final recording loop Quote Link to comment Share on other sites More sharing options...
