Single String 'gurgling' With Distorted Sound?
32 replies to this topic
#21 snhirsch
snhirsch
    Iknowathingortwo
  • PipPip
  • 286 posts
  • LocationBurlington, VT USA
Posted 22 October 2013 - 07:07 AM
Sure sounds like fret buzz to me.  As hurghanico pointed out, a solid G string is always going to have the largest mechanical excursion and is definitely the most likely to sprout odd overtones as a result.
  • 1
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990) w/ GK-3 Hex PU
James Tyler Variax JTV-69(k) w/ Strat Neck
Roland GR-55 Guitar Synth
QSC K10 FRFR
#22 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 217 posts
  • LocationArizona, U.S.A.
Posted 23 October 2013 - 08:33 AM
Short of changing the bridge setup I will raise the G string on the nut. I realize that this will have no effect on any tone I finger on the G string, but it should remove the problem at least for the unfingered G (if fret buzz is the issue). Softer playing should remove or at least reduce the effect too. Did not notice I does, but will recheck. Thanks for feedback.
This is starting to get into territory I don't feel competent of messing around with (e.g. truss rod or bridge and subsequent other setup adjustments). Any recommendations on a good place to get such work done in Phoenix AZ area or good document(s) to read about this topic?
#23 hurghanico
hurghanico
    Power User
  • PipPipPipPip
  • 1261 posts
  • LocationBologna, Italy
Posted 23 October 2013 - 10:26 AM
for eventual truss rod adjustments there is this good video:
by the same guy there are also other interesting and well done guitar setups videos
http://www.youtube.c...FruduaTv/videos
  • 1
#24 hurghanico
hurghanico
    Power User
  • PipPipPipPip
  • 1261 posts
Posted 23 October 2013 - 11:18 AM
...also I heard that sometimes the magnetic pickups too close to the strings can cause odd warbling sounds..
it seems that until now you didn't try also to lower them, so why don't you give it a try (especially with the bridge PU) ??
some people solved a very similar issue that way
give a look at this fender forum thread: http://www.fenderfor...c_number=744617
  • 1
#25 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 217 posts
Posted 23 October 2013 - 12:49 PM
Hey, thanks a bunch hurghanico
Looks like I'll have a couple more things to try and will delay finding a setup shop in favor of learning a trick or 2 from the videos.
Sampled the trussrod one, and I am impressed!
Updates will have to wait a little as I won't be able to play for a few days.
#26 snhirsch
snhirsch
    Iknowathingortwo
  • PipPip
  • 286 posts
Posted 23 October 2013 - 02:16 PM
Worth a try, but in my experience having pickups too close primarily affects the low-E and A string.  On my JTV-69 I need almost 1/4" clearance on the bottom strings to avoid warbling, but there's no corresponding issues on the high side.
QSC K10 FRFR
#27 hurghanico
hurghanico
    Power User
  • PipPipPipPip
  • 1261 posts
Posted 23 October 2013 - 02:37 PM
yes, worth a try
everything is possible, you never know
I do not know if you've had a look at the external forum link at the bottom of my last reply ..
there the guy writes that he had the warbling problem with the first 3 high strings of a standard stratocaster and he finally resolved by lowering the pickups ..
hope to be so even in this case, as it would be the easiest solution
#28 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 217 posts
Posted 26 October 2013 - 06:57 PM
OK, had time to try a couple things. A little update for now:
  • It's not fret buzz (raise G string at nut and the gurgle is present even when I finger no note; not as bad as on high note, but still there)
  • It's not the bridge pickup height either (put it all the way down; no effect on gurgle besides my mags got quieter
That leaves the truss rod and possibly how the the piezo sits in the nut (maybe even the nut assembly itself). Need to do it little more research before I take it all apart and be confident I don't need a setup job after.
#29 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 217 posts
Posted 28 October 2013 - 02:28 PM
Tried the truss rod adjustment and found that I could not get it to move at all with the pressure I was daring to use.
It definitely does not feel loose, but seeing how easy the luthier in the video did this I suspect I need a pro that knows what he is doing (mine may not be working quite as intended).
Looked more into the nut and took both the G and B string ones apart and adjusted their height (just to see whether this does anything). Put it all back together and adjusted it to match the fretboard curve at different heights ... and it sounds just as badly as before.
Only thing I am suspicious of now is that the piezo on the G string is a tiny bit lower than the rest of the nut string indent. I cannot really see it but feel it going over it with my fingernail. Don't get quite the same feeling when I do the same on the working B string. Looks like i will be heading for a Line 6 service place unless someone has another thing to try.
Thanks for bearing with me.
#30 Charlie_Watt
Charlie_Watt
    Gear Head
  • PipPipPip
  • 832 posts
Posted 28 October 2013 - 02:39 PM
What you are calling the "nut" is actually the "Bridge".    Truss Rod adjustment nut is not easy to turn.  You would want to loosen it to add more relief.  If you are not comfortable doing this I would recommend that you take the guitar to an experienced luthier (Get some recommendations!!!!) to have it set up.  He can find any problems with neck or frets.
#31 hurghanico
hurghanico
    Power User
  • PipPipPipPip
  • 1261 posts
Posted 28 October 2013 - 03:46 PM
I heard also of some people who solved strange body resonance problems changing strings gauge/tension..
#32 roxrob
roxrob
  • 5 posts
Posted 29 October 2013 - 10:58 AM
Hi, just got my JTV69 yesterday and I've noticed that the alternative tuning wheel vibrates with certain notes, which I dont hear amplified (thankfully) but am a little annoyed. Maybe a similar thing with yours but perhaps the piezos in the bridge are picking up the vibration?
Worth a try?
Rob
#33 MartinDorr
MartinDorr
    Iknowathingortwo
  • PipPip
  • 217 posts
Posted 29 October 2013 - 01:29 PM
Thanks for additional feedback.
Yes, I was a nut and I meant the individual string saddles of the bridge.
Ordered a set of strings with a wound G string (D'Addario Chromes Jazz Light) - the web is full of references to bad G string sounds especially for distorted sounds.
And I'll check the tuning wheel, althought I thought I already did in the very beginning.
