Reason Doesn't Recognize Line 6 Gx As An Audio Input
reason line 6 gx
2 replies to this topic
#1 davidBichsel
davidBichsel
  • 2 posts
  • Registered Products:1
Posted 10 October 2013 - 01:27 PM
Hello
I've downloaded a Demo Version of Reason an tried recording guitar with the GX. This did not work. In the tutorials i've seen reason seems to recognize the GX automaticly as the audio input if the Gx is connected and POD Farm opended.
In my case the audio input is "Direct X Full Duplex Driver Microphone" which is the microphone of the laptop. The Audio input can't be changed. This is especially wierd because when i plug the gx out reason tells me that i now have less amps. So it does notice that the GX is pluged in. How can this problem be solved?
Thanks for your help
David
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 11 October 2013 - 04:55 AM
Run the newest version of the Monkey to make sure everything is current.
http://line6.com/software/
Then in Reason when selecting your audio device you should see something like : Line6 GX ASIO.
#3 davidBichsel
davidBichsel
  • 2 posts
Posted 12 October 2013 - 11:54 PM
I tried that it didn't work. Should i uninstall reason and pod farm? Could it make a difference which one I reinstall first? Could the problem have anything to do with the fact, that I'm using only a Demo-version of reason?
Thanks
Also tagged with one or more of these keywords: reason, line 6 gx
