Adjusting Dual Amps
8 replies to this topic
#1 ts14064shred
ts14064shred
  • 10 posts
  • Registered Products:3
Posted 10 October 2013 - 06:12 PM
First of all, thank you MEAMBOBBO and PDXGUITARFREAK, for your generous contributions on the HD500, you guys are incredible. I've been playing for 40 years, and own/have owned more tube amps or digital rack/pedal stuff than anyone should be allowed to (that now just records in their bedroom on the weekends), and am having a blast with my HD500X EVH tones, Floyd tones, etc. Man this thing is fun in stereo! Anyway, what is the best method for dialing in 2 amps on the same preset. If I dial them in separately for their best individual sounds, it's not necessarily the best mix. So I end up just being tweek boy, hoping for the best combined tone. I know I should obviously start with a tone in my head, but do any of you super users have a method I can employ, rather than just tweeking and changing amps and random perimeters, hoping to nail a killer combination? (I am using the HD for both the preamp and amp tones, direct).
#2 evilmikehoo
evilmikehoo
    Iknowathingortwo
  • PipPip
  • 166 posts
  • LocationBrandonville, PA USA
  • Registered Products:5
Posted 11 October 2013 - 02:36 AM
Did you check out this post? It might be helpful. http://line6.com/sup...old/#entry20263
#3 ts14064shred
ts14064shred
  • 10 posts
Posted 11 October 2013 - 03:48 AM
If you mean MEAMBOBBO's topic on "Pure Gold", you bet. Thank you. I am having fun with EQ's, but I was wondering how to get to the best dual amp tones first, before coloring them up with other EQ or FX.
#4 rootmusic
rootmusic
  • 89 posts
  • Registered Products:7
Posted 11 October 2013 - 04:22 AM
try assigning the level of each to either end of the expression pedal(ie100% amp1 0% amp2 at one end and vice-versa at the other), then you can rock that back and forward whilst you play until you find the sweet spot.
#5 ts14064shred
ts14064shred
  • 10 posts
Posted 11 October 2013 - 06:19 AM
Thank you, I'll give it a try.
#6 HDProJohn
HDProJohn
  • 71 posts
  • Registered Products:2
Posted 11 October 2013 - 09:38 AM
I'm not a super user like the others mentioned, but if I set up a dual amp patch, I'll get the basic tone I want with one amp/cab/mic, mimic the amp settings for the second, and change the cab/mic option to find the complimentary tone (this usually means finding more body). Once the two work together nicely, I'll begin fine tuning and addressing the tonal nuances.
#7 evilmikehoo
evilmikehoo
    Iknowathingortwo
  • PipPip
  • 166 posts
Posted 11 October 2013 - 10:02 AM
I may be mistaken, but I think He's talking about using one patch for two actual, physical amps. Am I wrong here? I initially believed it to be a dual amp patch, but after rereading the post, I'm not sure.
#8 ts14064shred
ts14064shred
  • 10 posts
Posted 11 October 2013 - 10:51 AM
Thanks for all your replies, it's all been helpful. And just to clarify, I'm not using any physical real amps, only the full amp simulations from the HD.
2 similar or different amps in stereo, on the same patch.
#9 brian6string
brian6string
  • 81 posts
  • Registered Products:1
Posted 11 October 2013 - 07:37 PM
Look at this for some ideas (X3 ideas apply here too).
One technique I like is to mix two models of the same amp, just mic them differently (on axis vs. off axis, condenser vs. ribbon). Pan both to the center. A lot of studio engineers do this with when recording real amps.
Another technique is to find two amps that contrast. Dirty vs. clean, bassy vs. mid rangey. Pan these hard to the L & R. Also try putting a very short 100% wet delay on one side. This will make the sound get to one ear a little later than the other and gives you better stereo separation. Combos I like: AC30 & Plexi, AC30 & JCM800, Dual Rectifier & Peavey.
