Pod Hd Desktop: Recording Inputs 1 And 2 To Separate Tracks
Best Answer silverhead , 12 October 2013 - 05:31 AM
Here's a preset you can use as a model. I created it a long time ago so that you could record the Wet and Dry signals simultaneously from the Pod, but you can adjust as desired EXCEPT don't mess with the signal flow structure - don't put anything before the path split. Read the comments with the preset for DAW setup.
http://line6.com/cus...one/tone/217206
Also, this was created for the Pod HD500. TYo use it with the HD Desktop you will need to run it throught the Pod HD patch converter utility:
http://www.jzab.de/content/pod-hd Go to the full post
4 replies to this topic
#1 templeofhorse
templeofhorse
  • 9 posts
  • Registered Products:1
Posted 12 October 2013 - 02:51 AM
hay guys, im using reaper to record the pod desktop. i assign input 1 and input 2 to separate tracks but both tracks record the same sound at once. id like to separate the vocal and guitar for mixing reasons. ive never had this problem with other interfaces, thanx heaps
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16051 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 12 October 2013 - 05:31 AM   Best Answer
.... John Lennon
#3 templeofhorse
templeofhorse
  • 9 posts
Posted 12 October 2013 - 01:20 PM
hay Silverhead, cheers for the solution to my problem, works a treat! Awesome mate!
cheers, andy
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16051 posts
Posted 12 October 2013 - 02:46 PM
Glad to hear it. Have fun!
.... John Lennon
#5 templeofhorse
templeofhorse
  • 9 posts
Posted 12 October 2013 - 09:11 PM
ive used the pod converter before and has never worked on my computer for some reason. i just renamed the file to .hbe and worked a charm bro. Cheers
