Putting 11's On Jtv 69
20 replies to this topic
#1 broker2
broker2
  • 76 posts
  • Registered Products:1
Posted 12 October 2013 - 06:02 AM
Did anyone put 11's on their jtv 69, if you did ,did you have any problems with the nut or did the strings fit with no problem thanks for your help.   cal
#2 tomb68
tomb68
  • 51 posts
  • LocationTejas
Posted 12 October 2013 - 06:26 PM
I have tried 11's 10's. 9's and now 8's. no issues with the nut slots. The 11's lasted a day though, too much tension to comfortably play. The JTV's should be like any guitar in regards to string gauge. Play what feels good to you, though some adjustment may be necessary. I'm currently using 8's on mine and will probably stay with that.
#3 tscoolberth
tscoolberth
  • 65 posts
Posted 12 October 2013 - 06:43 PM
11s on my JTV 89, slight intonation adjustments needed ..otherwise its fine.
JTV-89, Ibanez 7421, ESP-LTD Hex-7, Schecter V-1, Legator Helios, Jackson KVXMG,
Laney IRT Studio head, Randall RD45
#4 pugdealer
pugdealer
    Iknowathingortwo
  • PipPip
  • 234 posts
  • LocationPortugal
Posted 13 October 2013 - 11:40 PM
It's fine...just put what you feel it's best for you! I use 0.11s myself, though on a 59...
You'll need some intonation adjustment once you change gauge, but then again, you would anyway with 0.10s, as the guitars hardly ever come intonated, and specially having a tremolo + the natural expansion/contraction of the wood with temperature/humidity/time, it's guaranteed you need to fiddle with intonation.
#5 broker2
broker2
  • 76 posts
Posted 14 October 2013 - 05:49 AM
Thanks guys for your help.  cal
#6 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 14 October 2013 - 08:19 AM
On a JTV69 you may have to adjust the Trem Springs to compensate for the increased string Tension with 11's to get the bridge level.  (More spring tension required)
#7 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1223 posts
  • LocationUK
Posted 15 October 2013 - 04:13 AM
I just put Elixir 11s on my 69 having previously only used 10s.
I had to tighten the trem springs obviously to balance the trem position
Acoustically it is a lot louder, but it seems to have lost dynamics and when using models there is a sort of whaa sound when strumming which I really don't like.
My suspicion is that with the heavier strings and much harder contact on the peizos that the signal level into the processor is higher and that there is some compression going on.  Has anybody else noticed this and did you manage to get back high dynamics, perhaps by setting the string volumes in workbench much lower?
#8 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 15 October 2013 - 06:02 AM
I don't think that the string tension changes the pressure on the Piezos.  They are spring loaded to the strings.  Dynamics will change though.  Lots of folks are using 11's on JTV's.
#9 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 15 October 2013 - 08:34 AM
The piezo transducers on my JTV-69 are definitely not spring-loaded (that would take one hell of a spring and a provision for adjusting tension to allow for different guages).  Using heavier strings definitely increases the downward force vector.  Whether or not that affects the sound is a completely different question.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 15 October 2013 - 09:46 AM
I do not think so.  The bridge supports the string tension and the piezo sticks up against the string.  That is how the old Variax piezo was and I thought that was how the JTV69 bridge works too.  I have not had mine apart so I could be wrong on that.  I know for sure that is now the original Variax bridges worked.  Piezo's were spring loaded up through the bridge against the strings.
#11 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 15 October 2013 - 12:02 PM
If mine were spring-loaded, they would rise when the string is removed.  They do not.  Are you saying that the bridge pieces on the original Variax models would rise up during string changes?
#12 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 15 October 2013 - 02:08 PM
Yes - slightly.  Not all that obvious.  You could replace the elements without replacing the saddle.  They fit in underneath and were spring loaded.  Not that was on a 500 with a fixed bridge.  I never had a 600 with trem.  I think it was the same though because both could be fitted with the Ghost pickups.  I put them on my 500.  Those were not spring loaded.  The piezo was potted into the saddle itself.
#13 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 15 October 2013 - 07:06 PM
Well I stand corrected!  The JTV69 Piezo's are not spring loaded.  They are hard mounted in the bridge with the full string tension on them.
#14 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1223 posts
  • LocationUK
Posted 16 October 2013 - 03:57 AM
And it is worth checking the global string volume settings in Workbench HD as the heavier strings definitely generate a stronger signal in the piezo elements.
This may be stronger than expected by the Variax processor which appears to have some sort of limiter/compression in place. Reducing the global string volumes down is required eliminate this effect and to get a dynamic response again - in my case I reduced some strings down to -7db (others a bit less) before I could notice any change in the output volume.
I now have the more dynamic response back again
#15 broker2
broker2
  • 76 posts
Posted 16 October 2013 - 05:11 AM
Think i will stay with 10's      thanks guys for your help   cal.
#16 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 16 October 2013 - 05:31 AM
It is very possible that some that do not like the sound of their JTV have the string volumes set too high.  If anything in the electronics saturates the modeling will be crap and it will sound terrible.  I experienced this on my old Variax 500 when I upgraded to Ghost pickups.  They had way too much output.  I had to reduce the string volumes to about 50% to get back to goodness.  I expected that so I did it right away.  It now sounds far better than it did with the original Piezos.
#17 Hey_Joe
Hey_Joe
    Gear Head
  • PipPipPip
  • 696 posts
  • LocationYorba Linda, CA USA
  • Registered Products:5
Posted 16 October 2013 - 02:38 PM
In the Line6 Blog - http://blog.line6.com/  the post with Sean Haley acoustic videos on a JTV69 he states: So if you’re on the latest firmware for your James Tyler Variax, and you’re not able to get close to this sound with a blank patch in your POD HD, you’ve got some playing and setup work to do. Remember the three most important variables: I’m using size 11 strings, I’m using a sharp pick and my fingers at the same time, and I’m playing very lightly.
Just thought I'd through this in here.
#18 lectricfrets
lectricfrets
  • 18 posts
  • Registered Products:4
Posted 18 October 2013 - 08:27 AM
I switched to 11's, made the physical adjustments,  and thought it made the acoustic models sound more natural, but they do lack dynamics (sound compressed).  I never gave increased piezo output a thought.  Kudos to Rewolf48 for bringing that up.  Firmware release 2.0 is reported to have lower output and more dynamics than 1.9.  Maybe it is a good match for 11's.  I haven't installed 2.0 because I save a preset for every song we do (lots of them), and I did not want to throw off their sustain and distortion characteristics.  Maybe it's time to give 2.0 a try.
#19 ponyk
ponyk
  • 6 posts
Posted 24 October 2013 - 08:23 AM
Hello-
my first time out here! i tried the JTV69,  and loved the sound, It was straight Guitar, no battery in it so I could try out the models, but i had read a lot of post about battery issues, charging not working, firmware glitches, blah blah blah. So I guess what I am asking is, have these issues been cleared up? Do anyone know or have an opinion on them? thanks
#20 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 24 October 2013 - 08:29 AM
Most of us have no problems.  The discussions here are skewed towards problems.  My 69S is perfect and has been since I got it.  Running latest 2.0FW
#21 lectricfrets
lectricfrets
  • 18 posts
Posted 31 October 2013 - 06:34 PM
You will have better luck getting your battery question answered if you start a separate thread.  The JTV generation of Variax has a much better battery system than the old Variax 300, 500, 700 versions.  That said, I don't use the battery at all.  I feel like my Line 6 HD-500 is the other half of a fine instrument.  It powers the guitar and lets you call up the guitar model, tone, volume, and tuning along with your effects presets with the touch of a footswitch.  I never use the guitar without the processor.  I don't think the PODxt Live controls the JTV Variax models, but it is a decent effects processor with a free USB based editor, that would at least power the guitar so you wouldn't have to worry about batteries, and you can find them used for about $150 now.
