Stagescape M20d - Personal Monitor Mixer?
stagescape personal monitor mixer m20d personal monitor mixer stage scape mixing
Best Answer line6jonb , 07 May 2013 - 04:02 PM
The L6 Link connection on the StageScape M20d is a output and not an input,and it looks like the same can be said for your Roland.  So the AES/EBU output on your Roland board would not sufficiently input to your StageScape.  However, you could use the StageScape as a monitor mixer by creatively assigning your Roland inputs to your assignable outputs which then feed into your StageScape mixer.  However, this is not necessarily the best setup because you wont have control over individual inputs if you have more inputs than you have assignable outputs on your Roland.  For example, if you have 3 guitars plugged into your Roland, and you group them to the same assignable output and plug that assignable output into your M20d, you will be able to send all 3 guitars to a monitor on the M20d, but you would not be able to control the individual levels of those guitars in the monitors without controlling the 3 guitar inputs on your Roland mixer.
I hope this is helpful.
Go to the full post
3 replies to this topic
#1 bently34
bently34
  • 3 posts
Posted 07 May 2013 - 01:58 PM
Is is possible to use the M20d as a personal monitor mixer? Just like the Roland M-48? The roland m-48 uses cat-5 connectors, and I was wondering if the AES/EBU connection can be used for digital signal input other than the L6 Link? I wanted know if I can use the m20d as a slave mixer (onstage)
#2 line6jonb
line6jonb
  • 69 posts
  • Registered Products:3
Posted 07 May 2013 - 04:02 PM   Best Answer
#3 bently34
bently34
  • 3 posts
Posted 11 May 2013 - 01:11 AM
Thanks for the help!  :)
#4 ChristianArnold
ChristianArnold
    Iknowathingortwo
  • PipPip
  • 264 posts
  • Registered Products:4
Posted 11 May 2013 - 05:11 AM
I dunno if this is what you are talking about but it may be helpful. http://youtu.be/u5tDN2FVjOM?t=1m55s
Check out all my youtube videos featuring Line 6 products here. www.youtube.com/christianarnoldmusic
Also tagged with one or more of these keywords: stagescape, personal monitor mixer, m20d, personal, monitor, mixer, stage, scape, mixing
