dRad402 Posted February 17, 2018 Share Posted February 17, 2018 Sorry, I did search and I found tons of information on how to set it up but I didn't see anything showing hardware needed and where to plug it in. Do I need a Midi>TRS Male cable? TRS Male>TRL Male cable? Regular 1/4 instrument cable? What port on the back do you use as the out? Thanks for any help you can give! Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 17, 2018 Share Posted February 17, 2018 You should be able to use a traditional standard instrument TS cable. This works just fine on my Marshall JTM312 and Marshall Silver Mini Jubilee with my Helix. Use the Ext Amp jack on the Helix. You also need to set the appropriate tip/ring or tip/ring/sleeve setting in Global Settings. Then you can assign a stomp button on one of your presets. It’s saved on a preset by preset basis. Personally I save it as a blank preset and then copy it over to all of my new presets. Hope this helps you. Quote Link to comment Share on other sites More sharing options...
dRad402 Posted February 18, 2018 Author Share Posted February 18, 2018 I totally missed that writing under the expression out. :) I'll test cables I have when I get the unit in the mail before ordering a new cable. Thanks! Quote Link to comment Share on other sites More sharing options...
