How Do You Conect Your Ipad...
87 replies to this topic
#61 jaminjimlp
jaminjimlp
    Iknowathingortwo
  • PipPip
  • 169 posts
  • LocationGeorgia
Posted 11 January 2014 - 11:50 AM
mind you I haven't never tried what you are doing but 1. iPad connects to router? and stay connected? 2. you open the M20D app and it never connects? 3. does the M20D show that it sees the router network?
May you be blessed and our Lord Jesus keep you!!!
#62 tinorios
tinorios
  • 74 posts
  • LocationNorthwest FL, USA
Posted 11 January 2014 - 03:18 PM
Update: It went from bad to worse. I gave up on the Belkin router and went back to the EnGenius EUB9801 and it still doesn't work.
Everything in the mixer is as the manual describes. The iPad settings are good. It recognizes the mixer as a WiFi device and let's me select it.
But when I open the StageScape Remote App, it does not find the mixer and it spins on and on.
Maybe my home WiFi is overpowering it. I also tried Channels 1 & 3 on the mixer with no results. I tried Channel 2 on the mixer also, but it wouldn't make a connection. I ended up leaving it on Channel 3.
Now, I'm tired of this. I'm going to leave it alone and do something else.
#63 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 334 posts
Posted 11 January 2014 - 05:38 PM
I've been trying to connect the mixer and iPad all morning with the Belkin N600 router and the Apple USB Ethernet adapter and I can't make it work. When I choose the Belkin 858 network in the iPad WiFi choices, it wants to connect to the internet and not the mixer. I'm totally frustrated, specially since it seems so easy reading about it in this forum. I've gone to the Belkin website and all they write about is connecting to the internet. I'm just about ready to go back to the USB dongle and return the router and adapter.
Is there a place where it is explained how to connect the router to the mixer?
When you choose belkin858 in the ipad, where is it trying to connect to the Internet? In the ipad "settings" app, on the "wifi" page, it should show the network, and a check mark beside the one it is connected to. The ipad won't "try to connect to the Internet" unless you open safari, or App Store, or something. But it is ok to connect to the Internet if it wants to. But once you see it on your ipad as connected to your belking, the , go to the settings page on the stagescape and then the "wifi" section on the stagescape, and you should see the network available to connect to. And a 4 digit pin. Then, once the M20d is connected to the belkin, and you ipad is too, you can open the stagescape app on your ipad, enter the 4 digit pin, and be ready to remote control the mixer.
#64 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 334 posts
Posted 11 January 2014 - 05:41 PM
Section 9.3 in the manual explains it. You want to "use with existing wifi network" and once that is selected, you will see your router. Connect to that.
#65 jaminjimlp
jaminjimlp
    Iknowathingortwo
  • PipPip
  • 169 posts
  • LocationGeorgia
Posted 12 January 2014 - 12:05 AM
I use the Engenius too, make sure the M20D is in "stand alone" mode then make the iPad connect to it and you should see a device down below the other networks it should be the M20D. sometimes [most times] I have to start stop and restart the M20D app and plug and unplug the Engenius dongle several times before it connects, mine seems to work better on channel 3 as well.
#66 Bassgumbo
Bassgumbo
  • 9 posts
Posted 12 January 2014 - 06:23 PM
Success!!!!  I did it as was recommended.  Factory reset Router, powered on and connected to the M20-d (via an LAN port on the router) with an Apple ethernet to USB adapter; iPad snagged the network, logged on with the router's password, and the iPad app hooked up faster than with a dongle.
The Belkin router gives several different networks to hook up to; the network named " _ _ _ Belkin.media" is the 5 Ghz network; the one without the ".media" is the 2.4/5 Ghz network.  You really don't have to do anything more than that for set-up.  Digital-sound had made the recommendation to change the password on the router; the Belkin unit comes with an 8-digit alphanumeric password already assigned (unlike the "0000" assigned to some routers), so resetting the password is needed only for convenience, and can be done with an iPad.  The 5 Ghz capability I think will be important, as I've got a Line 6 G30 on the way; hopefully it will cut down on the frequency of app, dongle and sometimes, iPad reboots needed during a gig.
It seems that there should be more thorough, less ambiguous and yes, less incorrect info on the Line 6 website (".. just use a dongle to hookup the M20-d..." from the set up video). for those of us who find it less than intuitive.  Thank goodness for all your help here!
#67 malcevansmusic
malcevansmusic
  • 45 posts
  • LocationUK
Posted 25 March 2014 - 02:42 PM
Is there a specific version on the Belkin router that I should use? Would this work? http://www.ebay.co.uk/itm/261430404618
#68 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 334 posts
Posted 25 March 2014 - 08:14 PM
The belkin n600 will work. It is the router dboomer was speaking of connecting earlier in this post I believe. Your link took me to the belkin n600.
Should be straightforward setup.
#69 dboomer
dboomer
    Line 6 Staff
  • Moderator
  • 2524 posts
Posted 26 March 2014 - 06:11 AM
The most frequent mistakes I see are not resetting the router before connecting it to the M20d and not plugging into the LAN port. Remember you are setting up a local network and not going on the internet.
After the router connected to the mixer you can go back using the GUI and change to the 5GHz mode only (assuming your router itself is capable of that).
Also USB to Ethernet adapters that are not Apple brand most likely will not work even though they may be specified to work with Apple products. Please use the Apple branded part.
#70 brianj402002
brianj402002
  • 70 posts
  • LocationSt. John's
Posted 26 March 2014 - 06:48 AM
I am using and Apple Airport Express with the Apple branded ethernet adapter. Never had a problem with disconnects until v1.2 upgrade. Is this a known issue with the update or should I reset my router and try again?
#71 dboomer
dboomer
    Line 6 Staff
  • Moderator
  • 2524 posts
Posted 26 March 2014 - 06:57 AM
I use the same and have had no problems.  You might check the firmware in your airport express.
I would suggest resetting the Apple express and connecting again.  In my case i use the same iPad but with multiple mixers.  I've found in that case deleting the setup in the iPad itself and then reconnecting is helpful
#72 brianj402002
brianj402002
  • 70 posts
Posted 26 March 2014 - 07:06 AM
Thanks..will give it a go!
#73 case67
case67
  • 34 posts
  • LocationSouthwest Germany
Posted 26 March 2014 - 07:26 AM
I use the latest Airport Express router together with the Apple USB to Ethernet Adapter and this works fine for me.
But i want to be able to switch off the 2.4GHz Wifi and use the 5GHz Wifi only for the iPad .
I use wireless Line6 microphones XD-V75 and they operate on the same 2.4GHz wifi range,
so i want to avoid any interference between the airport and the wireless mics.
Unfortunately it is not possible to switch off the Airport 2.4GHz
Does anyone here know a hardware hack or any other trick to switch off the 2.4GHz selectively, but leave the 5GHz in operation?
#74 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 334 posts
Posted 26 March 2014 - 12:15 PM
I also use the airport express and have had no disconnection problems.
I am just starting to look, but is there a way to set the airport express to 5ghz only?
Edit: looking at the post above this one more closely (actually finishing reading it ), I see there is no way?
#75 malcevansmusic
malcevansmusic
  • 45 posts
  • LocationUK
Posted 26 March 2014 - 12:19 PM
I think I'll give this one ap go then, and buy the Apple adaptor as recommended. Thank you!
#76 petepraise
petepraise
  • 41 posts
  • LocationScotland
Posted 31 March 2014 - 06:23 PM
I just bought the Belkin n600 it actually says play on the box when I went into the iPad wifi there were a few belkin options and one was labeled 5ghz so I was able to go strait to it. I had a USB to Ethernet already and gave it a go and after a shaky start it connected and seems fine now. It wouldn't connect and said no network adapter the router had went through its start up and the light changed from blue to orange I thought because there is no internet. I tried switching on the router and then quickly plugging in the USB so the desk looked for it before it got to the orange light and it worked. After that it seemed to connect ok the big test will be this weekend if it goes pear shaped I guess I'll just need to buy the Apple one.
What's another £25 when I've already spend £110 trying to get a stable connection 😡 (moan over)
PP
#77 dboomer
dboomer
    Line 6 Staff
  • Moderator
  • 2524 posts
Posted 31 March 2014 - 07:35 PM
Did you shut the 2.4G off?  You can do that in the advanced system setup software that came with the router.  Highly recommended.
#78 petepraise
petepraise
  • 41 posts
  • LocationScotland
Posted 01 April 2014 - 03:06 AM
Thanks Dboomer, I haven't done that.
Would I need to use a laptop to do it? I've had a 75 headset for a while, still in the box we don't use it in the group - although I might once I get used to it - but I'm going to use it when I'm playing guitar on my own so even just for that I would want to shut it off. And we've got a full day this Saturday to practice and get settings, were also playing the place in a few weeks so I'd want to shut it off ASAP and dial in a right good sound for the venue. I'm planing on trying my new mic and guitar then too.
PP
#79 dboomer
dboomer
    Line 6 Staff
  • Moderator
  • 2524 posts
Posted 01 April 2014 - 06:06 AM
Yes, you will need an external computer to be able to run the Belden editor program.
#80 petepraise
petepraise
  • 41 posts
  • LocationScotland
Posted 02 April 2014 - 12:36 AM
Thanks for that I'll check out the Belkin instructions. I hope it's a set and forget cos we couldn't start taking a laptop with us, we spent a fortune to get rid of it.
PP
