Eliminating Hum/buzz/static & Controlling Volume Changing Presets?
amp hum buzz static feedback volume
6 replies to this topic
#1 aschmidt21
aschmidt21
  • 10 posts
  • Registered Products:1
Posted 12 October 2013 - 11:36 AM
   I have the Spider IV 30 -- the old model, with just four presets.  When I change from one preset channel to another, on some channels I get hum/buzz/static, which disappears when I fiddle with the channel volume/drive knobs.  Is this just one of those things that everyone experiences or can I adjust something to eliminate/minimize that?  I also noticed that the volume differs from preset channel to channel -- goes way up or down as I switch.  Any way to standardize the volume so that it remains the same as I change channels?
#2 HellMek
HellMek
  • 4 posts
Posted 13 October 2013 - 03:27 AM
I have noticed some noice when i sit too close my computer, try move away from any electric things and see if it helps. Its also important to have a good quality cable to your guitar. I noticed big differences between good and bad cables.
#3 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2470 posts
  • LocationNew England
  • Registered Products:3
Posted 16 October 2013 - 05:45 AM
You can save your altered settings to the 4 preset locations, including any channel volume change you have made.  If you are using a guitar with single coil pickups, and have the compression setting dialed up, the noise will be noticeable until you hit a string.   You can adjust the compression settings and turn on the noise gate and adjust that to combat noise.
#4 aschmidt21
aschmidt21
  • 10 posts
Posted 17 October 2013 - 09:09 PM
"I have noticed some noise when i sit too close my computer, try move away from any electric things and see if it helps. Its also important to have a good quality cable to your guitar. I noticed big differences between good and bad cables."
I got the cable when I bought my amp -- Neutrik -- per the salesman's recommendation.  Is that good -- or good enough?  If not, what do you suggest?
#5 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2470 posts
Posted 18 October 2013 - 04:27 AM
Unless you have an old 'tube style' (non-LCD flat screen) computer monitor, the only RFI interference that you might get from your computer is if you are using a laptop with a power supply.  Humm/buzz can be checked in this situation by running the laptop on battery to see if the noise disappears.
#6 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 19 October 2013 - 04:55 PM
Noise in the signal varies with the amount of gain in the preset. The higher the gain in the preset the more noise you will hear. This is normal for all electronics.
#7 HellMek
HellMek
  • 4 posts
Posted 22 October 2013 - 09:06 AM
I think that is good enough :)
Also tagged with one or more of these keywords: amp, hum, buzz, static, feedback, volume
