Wrong Cable?
6 replies to this topic
#1 demonsk
demonsk
  • 4 posts
  • LocationDen Helder, Netherlands
  • Registered Products:3
Posted 13 October 2013 - 01:12 AM
Hi guys i am new to the forum,
I have bought me a new jtv 59 and i like it very much but there is a problem.
When i want to use the modeled guitars i have to pull back the plug a little and fiddle with it to get it working.
I am using a regular guitar cable that is working fine with my other guitars.
Do i need to use another cable or is there something wrong with the input of my jtv 59.
I hope you can help me out, thanks
John
#2 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
  • Registered Products:4
Posted 13 October 2013 - 04:29 AM
The JTV doesn't distinguish between pickups and modelling at the 1/4inch jack. So "fiddling" with the cord should have the same effect on both. Are you sure it's a normal Mono cable and not a stereo cable?
Other than that, it could be a bad connection, but the problem should be on both the pickup and modelling modes if jiggling the cable fixes it.
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2514 posts
  • Registered Products:6
Posted 13 October 2013 - 05:15 AM
Plugging in the 1/4 inch cable activates a power switch as well as making the connection to your amp.  It sounds like that power switch isn't getting activated.  You may have a defective switch.  Try another guitar cable first though.  Maybe yours isn't quite activating the switch properly.
#4 demonsk
demonsk
  • 4 posts
Posted 13 October 2013 - 05:39 AM
Ozbadman
I am using a mono cable, and really, when i connect the guitar plug the pickups are working .nicely.
But when i want to switch on the modeling knob nothing happens.
So i have to pull back the plug a little until i can get the modeling working.
Thanks for replying Ozbadman
John
#5 demonsk
demonsk
  • 4 posts
Posted 13 October 2013 - 05:42 AM
I 'll try that, have to buy a new one first though
#6 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
Posted 13 October 2013 - 10:58 AM
I like Charlie's idea. I don't have my JTV with me, but is their any power indication on a JTV when a cable is successfully plugged in in modelling mode? Does a light come on? If Charlie is right, when the JTV is not working, there shouldn't be any light on on the JTV as it will be powered down. The jiggling would then bring the power up and therefore, the light.
#7 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2514 posts
Posted 13 October 2013 - 12:52 PM
The mag pickups work with no power.  The modeling will not engage until you press the modeling knob when power is applied through the switch in the 1/4 inch jack.  The mag pickups also work when power is applied if the modeling is not enabled.
