Period Of Silence When Switching Between Patches On Hd500
hd500
4 replies to this topic
#1 timothybaugh
timothybaugh
    Iknowathingortwo
  • PipPip
  • 189 posts
  • Registered Products:12
Posted 14 October 2013 - 06:55 AM
I have found that everything goes silent for a split second when switching between patches on an HD500. Is there anyway to fix this?
The HD500 is connected to an amp using the four cable method.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16060 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 14 October 2013 - 06:58 AM
There is inevitably a lag of a fraction of a second while the device loads a new preset. This is usually not very noticeable, but it is there. There is a more noticeable lag when connected via usb to your computer and running the editor. If you are connected when noticing this, just disconnect.
.... John Lennon
#3 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1102 posts
  • Registered Products:3
Posted 14 October 2013 - 07:51 AM
not much to do about it besides timing your changes live.....its really almost non-noticeable unless you're playing on your own.
The amount of effects/what they are can affect the changeover time as well...its takes longer to load a clean tone with 7 effects that a dirt tone with just a gate and a boost, so for live think about less DSP intensive effects where you can, as well.
#4 pfsmith0
pfsmith0
    Gear Head
  • PipPipPip
  • 616 posts
Posted 15 October 2013 - 09:32 AM
Not to be disrespectful to the above posters, but Idisagree. The gap is most definitely noticeable - even in a band setting. There is nothing you can do about it. You have to work around it. I'm at the point where I try not to use ABCD patch switches anymore. Only 1-2-3-4-5-6-7-8 FX switches. It works well but limits your sounds to only 1 amp per song, unless you setup a dual-amp configuration in which case you're limited in how many effects you can add in. Removing ABCD patch switches also complicates turning on-off multiple FX with one stomp. So you have to pick which limitation you're willing to work around.
  • 1
#5 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1102 posts
Posted 15 October 2013 - 09:34 AM
I gotta meet these people who play in bands that all go silent in between patch changes.....
Also tagged with one or more of these keywords: hd500
