Dt50 Hd500 Computer Usb Noise Whhite Buzz
Best Answer ozbadman , 20 October 2013 - 01:54 PM
Do NOT install this between the power amp and the speaker. IT WILL START A FIRE.
This is designed for signal levels. You could install it after the HD500 and before the DT, but only if you're not using L6 link.
Go to the full post
4 replies to this topic
#1 dbennett1152
dbennett1152
  • 8 posts
  • Registered Products:2
Posted 20 October 2013 - 01:03 PM
buy a behrinnger hd400 hum destroyer install at 1/4 inch power into speaker.  quite as a mouse
#2 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
  • Registered Products:4
Posted 20 October 2013 - 01:54 PM   Best Answer
  • 2
#3 dbennett1152
dbennett1152
  • 8 posts
Posted 21 October 2013 - 01:05 AM
hd400hum destroyer cool to touch  what gets hot:?
#4 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 21 October 2013 - 06:52 AM
I guess it will get quiet as a mouse with high power coursing it's way through a line level device causing it to burn to a crisp. LOL
On a more serious note, If I'm not mistaken only a proper Attenuator can be placed between the power output of the amp and the speaker. I've been looking into it a lot lately as I'm interested in the Jettenuator.
#5 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
Posted 21 October 2013 - 05:20 PM
The wires inside. Power amp currents are large, so you need thick wires. If the wires are thin (as they would be for line level devices), the wires overheat and catch fire. Their current rating is much lower than you would need.
Also, a power amp is designed for a particular impedance, often 8 ohms. If it isn't connected to the correct impedance, lots of things can happen, including damaging your power amp.
