DrFix Posted October 21, 2013 Share Posted October 21, 2013 Hi, I would like to by two KRK ROCKIT 5 G3 studio monitors (http://www.krksys.com/krk-studio-monitor-speakers/rokit/rokit-5.html) and connect them tirectly to my Pod HD Pro via two XLR cables, with no power amp. Is it possible? Will it work right? Thanks a lot Quote Link to comment Share on other sites More sharing options...
DrFix Posted October 21, 2013 Author Share Posted October 21, 2013 Ok, thanks, I meant with a separate amplifier between pod and rockits, but I don't need it. I'm also lookng at behringer truth b1031a, wich are cheaper and seems to work good.. Quote Link to comment Share on other sites More sharing options...
GTLazer Posted October 21, 2013 Share Posted October 21, 2013 I run an HD500 into a pair of Rokit 5 G2. XLR out is at mic level, so it's not very loud, even with the monitors turned right up. With the 1/4" outs I could take the roof off, but it means I can't use the ground lift. I vaguely recall reading somewhere that you can set the XLR outs on the Pro to line level to avoid this problem. Someone else would have to confirm this... Edit: Yes, you can; there's a switch on the back of the Pro to select Line or Mic. Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 21, 2013 Share Posted October 21, 2013 They will work fine. I use a different brand of 5" studio monitors. Like GTLazer says, set your HD Pro outs to Line level. Also - I would avoid connecting a bass guitar to the HD Pro. The 5" speaker could easily blow with the low bass frequencies. Quote Link to comment Share on other sites More sharing options...
