Jtv 69 - No Power
4 replies to this topic
#1 geetarist_ChImP
geetarist_ChImP
  • 6 posts
  • Registered Products:1
Posted 21 October 2013 - 02:56 AM
Hi guys.  No amount of forum searching has helped me out here.
College has got a JTV-69 that will no longer power up.
The battery is full, there is a jack connector and the VDI cable is connected.
When I push the modelling button, nothing happens...
Until last Wednesday it worked fine.
I have a feeling one of the students has plugged the VDI into a Spider 3 120 combo and that might have something to do with it.
Any ideas?
Cheers folks
Bob
#2 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 21 October 2013 - 01:26 PM
Search the forums for discussion of the model selection knob issue.  Basically, tolerances for the selector knob and control assembly are off such that it cannot be pushed down far enough to turn on the guitar electronics.  Try pulling the knob off and pushing the shaft directly with your finger.  If that does the trick, just shim the end of the shaft with a little disk of cardboard and push the knob back over that.  This is extremely common with the JTV-69.  Mine did it too and it scare hell out of me until I figured it out :-)
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#3 airmanchairman
airmanchairman
  • 7 posts
  • Registered Products:10
Posted 11 November 2013 - 03:36 AM
Same issue here, Line 6 support suggested exactly that, but no amount of toggling the bare encoder shaft would restore power to my Lake Placid Blue baby...
So here I am sadly parcelling it up again for a return - don't have the electrical skills for measuring current/voltage at various points of the circuit board, I'm afraid.
I was hoping a propellerhead would point me towards what wires to/from the battery and other main feeds to check.
Bummer... was just getting set to download the new sounds and all, first unboxing and tryout as well...
#4 airmanchairman
airmanchairman
  • 7 posts
Posted 27 November 2013 - 08:36 AM
On the advice of Line 6 Support, the unit was returned to the vendor as having a defective power supply or circuit board, and a replacement unit sent, which I received recently and am well pleased with as its firmware is already upgraded to 2.0.
#5 geetarist_ChImP
geetarist_ChImP
  • 6 posts
Posted 19 December 2013 - 11:57 PM
I sent it off to Line 6 as it was still under warranty.  Turns out it needed a new board.
I still haven't figured out what happened, and as usual none of the students ever did anything.
I'll put it down to a mystery unsolved.
