Recording Help!
1 reply to this topic
#1 heath49036
heath49036
  • 13 posts
  • LocationMichigan
Posted 21 October 2013 - 04:19 PM
Hello,
Is it possible to run my hd500 in to my digidesign Mbox2 and record directly? Is there a tutorial on how to do this? I'm running win7 pro. 64bit. Thanks
Heath
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15916 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 21 October 2013 - 06:21 PM
Yes - but you can only use one of the devices as your audio interface at any given time.
If you use your Mbox as the audio interface you would not connect the HD500 via usb to your computer. You would connect the HD500 outputs to your Mbox and then record using your Mbox as usual. You could use either the analog or s/pdif outputs from the HD500.
If you want to use the HD500 as your audio interface you would connect it via usb to your computer and you would not use the Mbox at all. You would record directly into your DAW from the HD500.
  • 1
.... John Lennon
