Main Out Level Dropping
6 replies to this topic
#1 FUMCGJ
FUMCGJ
  • 1 posts
Posted 21 October 2013 - 06:37 PM
We have 2 setups for our services, one for contemporary and one for traditional. After the last update, the mains drop to off every time we switch between setups.  Is there a way to save the main out level?
We are using the Stagescape M20d.
Thanks
#2 kmachman
kmachman
  • 70 posts
  • Registered Products:4
Posted 22 October 2013 - 05:20 AM
My mains have dropped to Zero when changing setups even before the firmware upgrade…  Not sure why it does that...
#3 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15705 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 22 October 2013 - 06:20 AM
That is normal behaviour. I guess the thinking is that a Setup is generally configured and saved with reference to a specific set of instruments in a specific venue/room. Hence, a change in Setup will load a configuration that may not be appropriate for the current set of instruments and room (volume, feedback, etc...). Accordingly the Mains Out is zeroed so that the user can proceed with caution and avoid an immediate unpleasant incident with excessive volume/feedback.
.... John Lennon
#4 litesnsirens
litesnsirens
    Gear Head
  • PipPipPip
  • 984 posts
  • Registered Products:5
Posted 22 October 2013 - 06:46 AM
This is also true of the monitor sends and for the exact same reason.  You don't want to load a new setup and suddenly be greeted with a bunch of feedback because the new settings are hotter than what you currently had.
  • 1
#5 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 576 posts
  • LocationGeorgia
  • Registered Products:11
Posted 24 October 2013 - 06:13 AM
Okay I can see a new feature for our next firmware update which would be, a small check box when you would load a complete scene or setup you would be able to check the box that says "load with previous volume settings"
May you be blessed and our Lord Jesus keep you!!!
#6 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15705 posts
Posted 24 October 2013 - 06:52 AM
That would be the second check box. The first would say something like "I hereby indemnify and hold harmless Line 6 from any damage to equipment or persons resulting from excessive volume and feedback."
  • 1
.... John Lennon
#7 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
  • Registered Products:7
Posted 24 October 2013 - 08:00 PM
I think the main volume remains the same level when switching "scenes". Could you configure a "scene" to do what you need?
