Sv Pre/power Amp Connection
8 replies to this topic
#1 AntonisPat
AntonisPat
  • 35 posts
  • Registered Products:6
Posted 23 October 2013 - 01:42 AM
Hi all
This might sound as a noob question (but then again I am one  :) )..
I'm trying to understand how the SV series (MKII 112 in my case) is set up..
Is it :
- Bogner preamp tubes --> line6 effects /sims --> bogner power amp tubes?
- Line 6 effects/sims ---> preamp ---> power amp
 or something else ?
Also is there a way to overlap the modeling part and just use the MKII as a tube preamp/amp?
I'm guessing that if I just use the "power amp in" , it bypasses the preamp/modeling sections (is this true?) but is there a way to also use the preamp section too??
...btw, this is pure curiosity, I'm very happy with the amp sounds!
Thanx in advance!
#2 napynap
napynap
    Iknowathingortwo
  • PipPip
  • 284 posts
  • LocationPalmdale, CA
  • Registered Products:4
Posted 23 October 2013 - 08:20 PM
AntonisPat,
   It's difficult to definitively answer your question, (which I feel is more than just a curiosity for you), but with the following info, maybe it will help you find an answer.
Resources:
Line6 Spider Valve Advanced Guide:
http://line6.com/support/manuals/sv112
   Preamp Out: Use the Preamp Out to send your Spider Valve MkII DSP Amp and FX modeling output to an external power amp, guitar amp or FX device.
   Power Amp In – Plug into your Bogner-designed power amp here. ...for example, driving the all-tube power amp.
Sv-pre By Strymon
   http://line6.com/sup...pre-by-strymon/
Line 6 Spider Valve MKII 1x12 Combo Amp Review
   http://www.premiergu...ombo_Amp_Review
   Preamp Out grabs the signal after the Line 6 modeling pre but before the Bogner-designed tube pre.
#3 AntonisPat
AntonisPat
  • 35 posts
Posted 24 October 2013 - 12:44 AM
Hello napynap, thank you for your answer!
Actually it is a curiosity question, last week I had a gigg with my band in a small festival and the guitarist from another band came along and we started another discussion on amps and guitars. He was quite interersted in my 112 MKII and asked a few questions on pretty much what I'm asking, but all I knew to answer back is what's mentioned in the manual..I felt a bit bad not knowing so here I am!
"The first controls on the back are Power Amp In and Preamp Out. Preamp Out grabs the signal after the Line 6 modeling pre but before the Bogner-designed tube pre." (from : Line 6 Spider Valve MKII 1x12 Combo Amp Review)
Does that mean that Preamp out gets the modeling but NOT the preamp tubes???
So if I connect something as effects send-return there it will be  Modeling->effect loop->preamp tubes->power amp tubes?
Again sorry fi I ask something stupid but Im quite new in trying to understand how amps and effects work, all I know is from a few articles I've read!
#4 OmeRoon
OmeRoon
  • 33 posts
  • Registered Products:2
Posted 24 October 2013 - 02:07 PM
http://www.youtube.c...h?v=7XfluCJ3czk - here Reinhold himself explains what he did. ;-)
  • 1
Check out my band: http://www.3rdmachine.com
#5 AntonisPat
AntonisPat
  • 35 posts
Posted 25 October 2013 - 03:49 AM
Ok so from what I understand its modeling --> preamp --> poweramp.
Thanx guys!
#6 AntonisPat
AntonisPat
  • 35 posts
Posted 08 November 2013 - 01:07 AM
Hello all again
Since you are so kind, I have another question :)  :
I want to play at low volumes at home, but I still want to push the valves as much as possible to get that nice tone they give.
To do that, is it better to  play at a moderate channel volume and very low master or low channel and moderate master??
To make the question a bit more general, does the channel volume comes from the modeling and the master from the preamp/amp section or does the channel volume affect the preamp as well ? I'm guessing that the power amp part is 100% master volume, right?
Thanx again!
#7 OmeRoon
OmeRoon
  • 33 posts
Posted 08 November 2013 - 04:11 AM
I think this is what you are looking for:
http://koch-amps.com...aker-simulator/
Also check out this thread as it's more or less the same question:
http://line6.com/sup...me-on-mkii-212/
#8 AntonisPat
AntonisPat
  • 35 posts
Posted 08 November 2013 - 04:37 AM
Hey OmeRoon, thanx, but thats a 300-400$ extra cost which I'd rather not spend..
I also have the Line 6 UX2 sound card and mostly play through this at home, but I was wondering if I could do something to use the amp too..
The actual question here is which would sound better : high channel volume and low master or low channel and moderate master?
Does the channel volume affect the tube section (I'm guessing preamp??) or is it just a master volume matter?
What I'm trying to do is take the most out of the tubes at low volumes..
#9 tscoolberth
tscoolberth
  • 65 posts
  • Registered Products:1
Posted 20 January 2014 - 03:16 PM
and if you have the Strymon ... tubes-> modeling->pre-amp tubes->power amp tubes.  I've been tending on having the Strymon pre-amp maxxed to minimize the on board gain  :)
JTV-89, Ibanez 7421, ESP-LTD Hex-7, Schecter V-1, Legator Helios, Jackson KVXMG,
Laney IRT Studio head, Randall RD45
