Mixing A Recording In Daw After 1.2 Update
mixing protools
Best Answer actdmusic , 23 October 2013 - 11:36 AM
I just use the normalize function on my DAW to bring the level up to "normal" 0Db. No big deal ;)
Go to the full post
10 replies to this topic
#1 nickinfrance
nickinfrance
  • 66 posts
  • Registered Products:11
Posted 23 October 2013 - 08:17 AM
Hi all,
I have happily been mixing recordings imported into protools up to now. Today I did my first mix from a recording after the 1.2 update and I'm really struggling with the levels being too low. Anyone else experienced this? I'm having to push the gain up to near max and then bouncing to disk and pushing the gain up again in the mastering stage to get any volume.
I may have just made some error when recording in the first place but I can't think what...
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15914 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 23 October 2013 - 08:22 AM
I'm not sure about this, but I would check my Trim settings in the Setup. I think the recorded signal may be post-Trim, and pre-Level. If so, and if your levels are adjusted higher to compensate for a lower Trim setting then that could result in a low recorded signal. Try increasing your Trim levels and decreasing your channel Levels.
.... just a guess.....
.... John Lennon
#3 gordwait
gordwait
  • 88 posts
Posted 23 October 2013 - 09:23 AM
I just started trying to connect the M20d to Apple Logic on my Macbook with the 1.2 drivers, etc, and found the levels sent to the DAW to be fairly low,
but it sounds like it's on purpose.
User ArneLine6 quoted this:
"It is 24bit audio. The "0" on the M20d is at 0dBu which is an analog reference to encourage a good headroom and match any metering of analog gear that is connected. The full level before clipping is +15.4 dBu which is 0 dBFS, digital full scale. "
And I found out via googling that Apple Logic treats 0db on the metering as 0 dbFS (db full scale) ie if you go above 0 on Logic, that's clipping digitally.
In a nutshell, sending 0dBu from the M20d to Logic reads as -15.4db on Logic.
After reading a bunch of other resources, I'm ok with it that way, it does leave lots of headroom, and I set Logic to 24 bit audio to keep some more bits around.
Also, by experimentation, and by Line6 description I think yes, the USB audio out is post Trim, and pre fader, so if you trim your input very low, you will have a very low signal at your DAW..
Here's the thread:
http://line6.com/sup...ce-v12-upgrade/
My issue is I can't play audio back from logic to the M20d via USB.
I also see logic react to audio in from the M20d with a half second or so delay, so I too will have latency complaints if I ever get audio playback from USB working.
I'm still happy with the M20d for live work, but I was planning on selling my old Presonus firewire26 setup and use the M20d as a replacement. I wanted to take that cash to help pay for a line6 floor monitor..
#4 actdmusic
actdmusic
    Iknowathingortwo
  • PipPip
  • 105 posts
  • LocationPortugal
Posted 23 October 2013 - 11:36 AM   Best Answer
António Duarte
My Facebookhttps://www.facebook.com/AntonioCTD
Anya Karin - Soul Projecthttps://www.facebook.com/AnyaKarinSoul
Hit Machine Disco / Funk Party Band: https://www.facebook.com/hitmachinepartyband
Portuguese Rock Tribute Band: https://www.facebook.com/rockcassete
Iron Maiden Tribute Bandhttps://www.facebook...eamformetributo
My music School: http://rockgp.net
#5 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 23 October 2013 - 11:45 AM
Yes. .... Normalize is your friend :)
#6 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 581 posts
  • LocationGeorgia
Posted 24 October 2013 - 06:24 AM
In ProTools 10 I use audio Suite to add 10 to 15 dB of gain to each track I found that normalizing sometimes puts a little too much gain in the track so I have made a preset in pt 10 for 10 and 15 dB gain and yes it is for headroom.
May you be blessed and our Lord Jesus keep you!!!
#7 johnnybayless
johnnybayless
  • 1 posts
Posted 26 March 2014 - 12:19 AM
How do I load the driver to protools for audio streaming to and from the M20d just installing it on my system doesn't work.
I have protools 10 on mac osx snow leapard.
Thank you
#8 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 26 March 2014 - 09:24 AM
Macs use their built-in "Core Audio" feature and do not generally require loading any drivers.
#9 marcelbache
marcelbache
  • 5 posts
Posted 30 April 2014 - 08:46 AM
Hi all,
Hello,I met the same issue with low signal with my line6 stage scape.I installed a soft named line6 Monkey on the site but ,for nothing
  • -1
#10 BucF16
BucF16
    Iknowathingortwo
  • PipPip
  • 263 posts
  • Registered Products:8
Posted 01 May 2014 - 05:55 PM
No idea what I'm doing right but using Logic Pro X I've dumped the tracks into a new file and they've been just fine. Logic asks if I want to change the project to 48k, I say yes and tell it to create new tracks and away it goes.  Really been pretty slick.
#11 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 01 May 2014 - 06:30 PM
Yes ... You want to set your projects in your DAW to 48k sample rate. That will match the way they are recorded on the M20d
Also tagged with one or more of these keywords: mixing, protools
