Pod Xt Pro Tap Tempo Issue
Hi. I have a Pod XT Pro. If I switch to a delay patch, I can set tempo with the tap. However, if I change patches and then return to my original delay patch, the tempo returns to the patch's default, NOT the tempo set by the tap.
Any suggestions? Or is this just an insane oversight in the Pod XT Pro?
I don't save it. If I save it, it keeps the tempo. However, the way most multi-effects seem to work is that if you tap out a tempo, it keeps it, regardless of patch change, until the unit is reset. This way you can coordinate tempo across multiple patches.
  • 3 weeks later...
