Pod X3 Live Usb Device Not Recognized
error usb pod x3
Best Answer Alexsnowflake , 19 November 2013 - 05:44 AM
You are right, support is still available till end of this year. They couldn't provide a solution because Gearbox won't be updated.
But.... Last night after trying few things got it working and the funny thing is that what it causes Gearbox not to work on Mavericks is not Gearbox itself but the latest driver with the added support for Mavericks. This is what I did:
To remove driver 7.3.6
1- On a terminal run this command   sudo pkgutil --forget com.line6.driver.xtaudio.package (enter)
2- Then this sudo pkgutil --forget com.line6.driver.xtmidi.package (enter)
3- Reboot
To install driver 7.2.9
4- Downloaded driver version 7.2.9  http://line6.com/sof...a.html?rid=5675
5- Run the 7.2.9 driver package to install it and ended the process with a reboot
After that Gearbox is working on Mavericks, at least that was my experience.
Hope this helps
Alejandro
Go to the full post
41 replies to this topic
#1 redux
redux
  • 3 posts
Posted 25 October 2013 - 09:17 AM
Just as the title says, I'm running into this problem. When I connect my x3 Live via usb, my pc prompts that it doesn't recognize the x3. I've downloaded the latest Line6 Monkey.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 25 October 2013 - 10:40 AM
change usb ports, reboot, try different cables, and possibly download drivers outside of monkey....
just a few idea to get you started.
#3 Auriemma
Auriemma
  • 8 posts
  • Registered Products:3
Posted 25 October 2013 - 04:48 PM
Same issue here.
My info:
OSX Mavericks.  All latest L6 drivers and Flash Memory Updated (According to L6 Monkey)
Error reads:
Ignoring connection to POD X3 Live
Device has incompatible driver installed.
I have already... Changed ports, changed cables, rebooted several times, re-flashed, and reinstalled L6 apps.
Sometimes it transfers the tones across to Gears (3.2.7), sometimes it fails.
When it does fail I get:
POD X3 Library Error
Tone Transfer Failed
Reason: (Code 80009000C) MIDI device timed out waiting for a response.
(Hint: I am not using a MIDI device)
Even weirder... I created a new tone in Gears with my X3 Live plugged in, saved it.
It wont load to my X3 Live. The error:
Tone Load
Unable to Load Tone
Reason: (Code 8000A009) Unsupported patch type.
I need this fixed...ASAP!
--- Joe ---
More gear than talent
#4 redux
redux
  • 3 posts
Posted 26 October 2013 - 01:41 AM
Where can I download drivers manually? I don't see anywhere here in the line 6 website
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 26 October 2013 - 07:29 AM
top right of this page... select downloads and follow the menus
#6 shaggylane
shaggylane
  • 1 posts
  • Registered Products:2
Posted 27 October 2013 - 06:02 AM
I am having a similar problem with Gearbox since upgrading my iMac to Mavericks.
After launching Line6 Monkey, I was prompted to update drivers for my X3 Live to 7.3.6.  Updates were also loaded for POD Farm2 (2.5.6).
Once the updates were installed and computer restarted, X3 Live restarted, each time I launch Gearbox I get a pop-up window:
Ignoring connection to POD X3 Live.  This device has an incompatible driver installed.
After hitting "ok", it appears to load the tones from the POD into the Hardware Memory Window.  BUT the Gearbox window shows "No amp selected" and "No model loaded" in the two primary windows.
Looking at the Hardware memory window, the tone that is active has blanks in both tone 1 & 2.  Clicking on another tone, blanks them out immediately.........very strange behaviour.  Note, the tones are fully loaded on the X3 Live.
Evidently, there's an issue with the Mavericks upgrade and the subsequent driver update.
Any help would be greatly appreciated.
Regards,
Doug
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 27 October 2013 - 07:24 AM
guys, please start your own threads... .the original thread was for a PC problem not mac/mavericks
#8 redux
redux
  • 3 posts
Posted 28 October 2013 - 12:23 AM
Well, I've tried everything. Changed cables, changed ports, changed PCs, reinstalled/uninstalled drivers. I even tried to plug it to a PC with newly installed OS. Maybe the thing's broken
#9 ratliffmarkl
ratliffmarkl
  • 6 posts
Posted 28 October 2013 - 02:16 PM
Since I upgraded to Mavericks, I cannot get Monkey to recognize the new v7.3.6 driver, even though I've downloaded and installed it multiple times. And I cannot get MainStage to recognize income midi signals from my HD500.
#10 ratliffmarkl
ratliffmarkl
  • 6 posts
Posted 28 October 2013 - 05:01 PM
Resetting the ports on my MacBook eliminated all of my midi issues that started after upgrading to OS X Mavericks.
Try the following steps:
1. Shut down
2. Hold down the following keys simultaneously for 30 seconds and then let go:
        shift
        control
        option
        the power button
    (You will not see or hear anything)
3. Press and release the power button to start the MacBook, and quickly press and hold the following keys until the mac plays a tone:
        option
        command
        the letter p
        the letter r
    (The mac will play the same tone a few times and then continue booting)
In addition to these steps, I found that turning on my midi devices BEFORE plugging them into the mac was important.
#11 telbyte
telbyte
  • 3 posts
Posted 30 October 2013 - 07:51 AM
Problem OS X Mavericks and gearbox there is a solution.
#12 Alexsnowflake
Alexsnowflake
  • 8 posts
  • LocationArgentina
Posted 31 October 2013 - 12:03 PM
Same error when opening GearBox on Mavericks: "Ignoring connection to POD X3 Live. This device has an incompatible driver installed."
Setup:  iMac 2.7 GHz Core i5 8 GB, OS X 10.9, Driver 7.3.6, Monkey 1.6.5, GearBox 3.72.0, POD X3 Live Firmware Flash Memory 2.01.
Tried NVRAM/PRAM reset, changed USB cable, uninstalled the driver and installed again, re-installed GearBox with no luck.
Same setup was working on Lion.
Any help would be really appreciated
Tks
Alejandro
#13 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 31 October 2013 - 12:21 PM
Support is ending soon: http://line6.com/sup...egacy-products/
please contact Line6 directly if you require assistance
#14 Alexsnowflake
Alexsnowflake
  • 8 posts
  • LocationArgentina
Posted 31 October 2013 - 01:14 PM
Good point, I've just opened a ticket.
I'll update with the news.
Regards
Alejandro
#15 Uniquified
Uniquified
  • 4 posts
Posted 03 November 2013 - 08:23 AM
Any word? I just tried installing on Mavericks and have the same issue.
#16 steve5922
steve5922
  • 1 posts
Posted 15 November 2013 - 10:00 AM
Had the same issue with Gearbox and OSX 10.9. un-istalled drivers, downloaded Drivers 7.2.9 so for so good
#17 Alexsnowflake
Alexsnowflake
  • 8 posts
  • LocationArgentina
Posted 18 November 2013 - 03:11 PM
Regards
Alejandro
Answer from Support was Gearbox won't get updated for Mavericks, you can downgrade to ML or use a Windows based PC. Three things that I dindn't want to read. Maybe I'm wrong but PODX3 Live is not that old to not keep Gearbox updated. Anyway, like it or not that's the answer I've got.
Alejandro
#18 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 18 November 2013 - 04:01 PM
they did announce that they were ending support:
For registered product owners, Line 6 is pleased to provide technical support via phone and email free of charge. Effective January 1, 2014, Line 6 will cease live technical support of the Legacy products listed below. Doing so allows our Support Team to create and maintain the resources that owners of these products are encouraged to use when technical questions arise:
· Video Tutorials
· Knowledge Base
· Forum Community
· Product Manuals
Alternatively, technical support for these Legacy products will be available starting January 1, 2014 via telephone at a charge of $19.99 per call, or via email at $9.99 per incident. These support products can be purchased fromhttp://line6.com/store/.
Legacy products
§ POD X3 family
§ POD XT family
§ Variax
§ LowDown family
§ Vetta II
§ GuitarPort
§ TonePort family
§ BackTrack
§ X2 Digital Wireless Products
§ Riffworks Line 6 Edition
§ GearBox
§ Spider I/II/III
§ AX2/AxSys
§ Flextone I/II/III/Duoverb/HD147
§ POD Pro
§ Bass POD/Bass PODxt family
§ Studio Modelers/AM4
§ Floorboard/FB4/FBV4
Alejandro
#19 Alexsnowflake
Alexsnowflake
  • 8 posts
  • LocationArgentina
Posted 19 November 2013 - 05:44 AM   Best Answer
3- Reboot
Hope this helps
Alejandro
  • 1
#20 RedMaster88
RedMaster88
  • 1 posts
Posted 19 November 2013 - 10:28 AM
Downloading the 7.2.9 driver worked perfectly for me!
#21 amsdenj
amsdenj
    Gear Head
  • PipPipPip
  • 833 posts
  • Registered Products:8
Posted 15 December 2013 - 10:56 AM
But does the old 7.2.9 driver work with Pod Farm 2.5.6?
#22 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 15 December 2013 - 01:20 PM
yes.
#23 amsdenj
amsdenj
    Gear Head
  • PipPipPip
  • 833 posts
Posted 15 December 2013 - 06:38 PM
Ok, on Mac OS X 10.9 (Mavericks), doing the steps above causes Line 6 Monkey to show the Drivers are not installed, and attempting to reinstall the latest version no longer works. Tried it on two different machines. So now I have no working drivers and GearBox doesn't even partially work.
Guess I'll try Line 6 support before the end of the year.
I've been thinking about updating to the POD HD500, but don't because:
1. its been in production for a while now, and I don't want to get caught with old technology at this late date
2. not enough bass amp models
3. no mic preamp models
4. no acoustic guitar amp models
I use my POD L3 Live with a Variax 700, mandolin, electric guitar and some bass for performances. So I need the flexibility.
#24 amsdenj
amsdenj
    Gear Head
  • PipPipPip
  • 833 posts
Posted 15 December 2013 - 06:39 PM
I see that POD Farm doesn't really need the drivers unless you're using it with an X3 as the input/output device. I never do that, so I really only need the drivers for editing convenience. Hope Line 6 addresses this as Mavericks was introduced before the products were discontinued.
#25 pabloguitar
pabloguitar
  • 6 posts
Posted 16 December 2013 - 07:37 AM
Hello, I have a pod x3 live and on display there are this information:
usb firmware ver 0.00
It's a hardware problem?
I must change the my Pod?
The problem is that not possible to connect at PC because X3 live use only the usb port. Why isn' t possible to use the midi also? with a midi interface.
Someone can help me if there' s some software procedure for to resolve this problem?
Thank's
#26 Sigmeister
Sigmeister
  • 1 posts
Posted 29 December 2013 - 07:53 AM
Thanks Alejandro,
it worked for me
#27 kol-8
kol-8
  • 2 posts
Posted 11 February 2014 - 05:26 PM
same trouble gonna try
#28 kol-8
kol-8
  • 2 posts
Posted 11 February 2014 - 08:30 PM
It really worked, tnx u saved my lollipop... gotta run for a  gig now!
---LINE 6 SUPPORT:   :angry:  _¡I¡¡
#29 macribas
macribas
  • 2 posts
  • Registered Products:12
Posted 23 February 2014 - 10:06 AM
The link in Alejandro's post is not pointing to the right software. This is the current link for 7.2.9 (as of Feb 2014):
Get Download
#30 jeffreysumedh
jeffreysumedh
  • 16 posts
Posted 16 July 2014 - 11:11 AM
Hello Guys -
I recently got a used X3L and everything is functioning properly. However, When i want to install some good patches off the custometone website..My X3L would be able to work when connected via USB. It shows the device listed under device manager, but with a yellow triangle and it tells me error code - device cannot start.
I tried installing drivers off the website. tried on multiple windows computers with different windows OS(XP, windows 7). Still no change. When i called Line 6 tech support i was suggested to get the USB port replaced. My question is if its the port issue how can the device me detected in device manager to begin with?
Can you guys please help me fix this issue? I would like to use gearbox and get some cool patches Vs doing manual settings on the X3L.
Thank you for the help in advance.
#31 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 16 July 2014 - 11:26 AM
Hey There, I know this won't be a big help BUT can you connect the X3L via the midi/USB cable? Might be a workaround.
My X3L is doa in a box so I can't test it myself.
-B
Smell the glove.
#32 timcobham
timcobham
  • 4 posts
Posted 16 July 2014 - 01:47 PM
I had this - really wanted to use Gearbox.  I'm on a Mac and after a lot of back & forwards - took my drivers back to 7.3.6 and hey presto - everything works again :)
#33 jeffreysumedh
jeffreysumedh
  • 16 posts
Posted 16 July 2014 - 03:50 PM
I tried with teh USB cable - infact tried with three cables - no go...stil shows a yellow triangle under device manager.
I am using windows 7. Anyone who had the same issue can you throw some light on how you fixed it:?
Thank you.
#34 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 17 July 2014 - 06:31 AM
As a used X3L, was the former owner able to connect via usb?
There is a posibility of a bad USB port on the unit.
Usually WinXp will connect and slap the drivers in at the least.
I found a similar old thread for you to check out:
http://line6.com/sup...ew/thread/75394
Looking at some old threads, which had similar issues and if the X3L usb firmware version reads 0.00 things do not look good. I can't recall how to pull that info off the X3L but it should be in one of the menus I'd like to think.
http://line6.com/sup...ew/thread/58943
Edit: As its been a while since I've had a working X3L, I took a look at the manual - you can try uninstalling all the drivers and software than go to page 8-1 and try a fresh start.
If you have an extra or have a friend that has one try a different power supply too. IIRC when the PS aren't quite putting out enough juice they can cause some things to be screwy.
Good Luck!
-B
Smell the glove.
#35 jeffreysumedh
jeffreysumedh
  • 16 posts
Posted 18 July 2014 - 06:25 AM
Hey Bill - I am actually based out of India. Got this X3L off the ebay website from the US. I am not sure if the USB port has been working all this while before i got it or not. However, I had an issue with the Power adaptor So i replaced with the one i have which is 9v with 1.3amps. Do you think thats what is contibuting to cause this Issue? the USB port on that unit looks okay. I can try getting that USB port replaced. Any other Ideas?
Thank you.
#36 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 18 July 2014 - 06:36 AM
The power supply can do all sorts of things not having enough juice to spread around. You need a 9v AC 2,000 mA (2A) rating on the adaptor btw (you are running 240v over there so a convertor will be needed).
I would start there.
-B
Smell the glove.
#37 jeffreysumedh
jeffreysumedh
  • 16 posts
Posted 22 July 2014 - 06:28 AM
Hey Bill - Thanks for your help here. I tried with the 9v 2A Adapter as well. Its the same story. I think it all boils down to one fact that USB port may be broken? or are theere any other things that i can try?
Thanks.
#38 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
Posted 22 July 2014 - 06:53 AM
Sorry Jeff - I am at a loss at this point. You have tried all the usual ways to make sure its not something with the unit itself (that I know of at least).
-Different cables
-Different PCs (XP and 7)
-Deleting and reinstalling drivers
-Power Supply
If L6 Monkey would "see it" I would try a reflash of the memory as a last resort (but that is a wild guess on my part).
You could still try using a usb/midi adaptor (MAudio Uno) if you haven't already and try to read/write through those. You can always open a support ticket and L6 will let you know if there are any service centers in your area - you never know it "might" not be too bad.
-Bill
Smell the glove.
#39 pabloguitar
pabloguitar
  • 6 posts
Posted 22 July 2014 - 07:09 AM
Have You try to improve with MacBook platform?
Mybe, different OS, different software, different drivers.
I now don't have this possibility ( I have the same your problem with my X3 Live usb port) but if you can try it.... Mybe the problem is only with windows software and drivers.
Paolo
#40 jeffreysumedh
jeffreysumedh
  • 16 posts
Posted 22 July 2014 - 09:10 AM
Thanks Bill for the input. I did open a support ticket wit line 6 and they provided me the service center info.
Pablo - Thanks for your response as well. I shall try it on a Mac as well and see how it goes.
Regards.
Also tagged with one or more of these keywords: error, usb, pod, x3
